Fail to use the strnlsp function
panfang
I used dtrnlsp succesfully to solve a nonlinear optimization problem for my course project.
However, I failed to switch to the single precision version.
The compiler said:
error LNK2019: unresolved external symbol _strnlsp_solve referenced in function ..
And when I open the mkl_rci.h file, dtrnlsp_* is defined, strnlsp_* is not defined. Does that mean single precision TR nonlinear optimizer is not implemented or ..?
Could you give me some suggestions to fix this problem?
Thanks a lot for your help :)
Jaiesy
Gennady_F_Intel
for single precision - please try to use strnlsp*.* interfaces. There are some examples show how to use and link this routine. You can find this routine here \examples\solver\source\ex_snlsqp_c.c
--Gennady
Gennady_F_Intel
Jaiesy, can you please check the problem with the latest version 10.2. Update 7 released last week.
panfang
Thanks a lot for your reply. I really appreciated.
I will try this morning, and tell you the result :)
panfang
Hey, Gennady,
I downloaded the MKL library together with other C++ compilers. And the version is definitely not 10.2 Update 7 since under the folder
C:\Program Files (x86)\Intel\ComposerXE-2011\mkl\examples\solverc\source, there is only two examples called ex_nlsqp_c.c and ex_nlsqp_c_x.c which are related to double precision TR solver without constraint.
I searched online for the MKL 10.2 Update 7, I only find MKL 10.3 download link.
It would be great if you could provide me a link to download the MKL 10.2 Update 7 version.
BTW, Is there a way to check the MKL version if we download it with other softwares?
Jaiesy
Gennady_F_Intel
please see this article.
the link to update 7 I will send a little bit later.
--Gennady
panfang
Look forward to the download link :p
Thanks a lot : )
Jaiesy
