Failure of DGESVXX
Svein-Atle_Engeseth
Hi all,
I want to report a problem with DGESVXX.
When I compile my program that uses this routine with the option "initialize stack variables to an unusual value"
it fails when run with this message: forrtl: error (72): floating overflow. Without this option the program runs without problems.
This makes me doubt DGESVXX.
With DGESVX or GESVX there is no such problem.
I use VS 2017 and an Intel Fortran compiler 17.0 with update 6. 64 bit program.
Svein-Atle Engeseth
Gennady_F_Intel
We don't know such issue at this moment. Do you have the example of this case which we may compile and check the problem on our side?
--Gennady
Svein-Atle_Engeseth
Hi Gennady,
Attached are two files for a test case.
Svein-Atle Engeseth
