Full matrix storage in MKL LAPACK
topol555
Please, help me. I'm using dgels function (declared in mkl_lapack.h) from MKL LAPACK package in my program on C++. I can't understand how should I store my full matrix in one-dimensional array - in column-major or row-major format.
For example, if matrix A=
(1.0 2.0)
(3.0 4.0)
(5.0 6.0)
then the array should be
1.1) [1.0, 2.0, 3.0, 4.0, 5.0, 6.0] (row-major format) or
1.2) [1.0, 3.0, 5.0, 2.0, 4.0, 6.0] (column-major format).
And if Ax=b, where b is a vector (7.0, 8.0, 9.0), then b will be overwritten by the solution vector like
2.1) [x1, x2, 9.0] or
2.2) [x1, 8.0, x2].
TimP
In case you didn't find answers in MKL docs,
http://www.netlib.org/clapack/readme
describes the storage from the C point of view (column-major)
I think you would have to specify more about your usage to understand the second part of your question. However, in the cases where the result doesn't use all the entries of b, it is the leading entries which are over-written.
Gennady_F_Intel
Quoting - topol555
(1.0 2.0)
(3.0 4.0)
(5.0 6.0)
2.2) [x1, 8.0, x2].
Please look at the following link:
ttp://software.intel.com/sites/products/documentation/hpc/mkl/lapack/mkl_lapack_examples/index.htm
you can find there the C example of DGELS routine.
/* Solve the equations A*X = B */
dgels( "No transpose", &m, &n, &nrhs, a, &lda, b, &ldb, work, &lwork, &info );
--Gennady
topol555
Thank you!
