GaussianMV parameter error
jaureus
Hello, I am trying to work with the random number generator of the mutlivariate Gaussian distribution in FORTAN. TO this end, I have compiled my MKL library, and am attempting to get the random numbers.
1. I have several questions. One it is hard to tell from the documentation. whether ytou need the Cholesky decompostion, or the full covariance matrix. which is required
2. When I attempt to run the below program, I recive the following error: Parameter 4 was incorrect on entry to vsRngGaussia
Does anyone have any suggestions as to what is wrong with my code. Please also note that I have tried using the Cholesky decomposition code from LAPACK but it does not seem to work.
program mcnet
implicit none
integer :: i, j
real :: harvest1, harvest2, sd
integer :: dimen, seed_in1, seed_in2, n_rand_obs_in
real , dimension (:, :), allocatable :: newidentity, sigmanew, meanvectnorm, meanvectnormtrans, meanvect, meanvecttrans, &
meanvectold, meanvecttransold, Q, r_mvgaussian_list1, r_mvgaussian_list2, sigmanewchol, newidentity2
interface
subroutine gaussianmv_rng_mkl(seed_in, n_rand_obs_in, r_mvgaussian_list, dimen, mean, tcv)
implicit none
integer, intent(in) :: seed_in, n_rand_obs_in, dimen
real, dimension(1:n_rand_obs_in, 1:dimen), intent(out) :: r_mvgaussian_list
real, dimension(1:1, 1:dimen), intent(in) :: mean
real, dimension(1:dimen, 1:dimen), intent(in) :: tcv
end subroutine gaussianmv_rng_mkl
end interface
! allowing for easy changes in dimensionality
dimen = 3
n_rand_obs_in = 3
allocate(newidentity(1:dimen, 1:dimen))
!allocate(sigmanew(1:dimen, 1:dimen))
allocate(meanvectnorm(1:dimen, 1:1))
allocate(meanvectnormtrans(1:1, 1:dimen))
!allocate(meanvect(1:dimen, 1:1))
!allocate(meanvecttrans(1:1, 1:dimen))
!allocate(meanvectold(1:dimen, 1:1))
!allocate(meanvecttransold(1:1, 1:dimen))
!allocate(sigmanewchol(1:dimen, 1:dimen))
allocate(newidentity2(1:dimen, 1:dimen))
allocate(r_mvgaussian_list2(1:n_rand_obs_in, 1:dimen) )
allocate(Q(1:dimen, 1:1))
!allocate(tcv(1:dimen, 1:dimen))
newidentity = 1.0
!scaling factor as per algoritm
sd = (2.38)**2/dimen
meanvect = 0.0
meanvectnorm = 0.0
do j = 1, dimen
! identity matrix times scaling factor as per Roberts and Rosthenthal (2009) gives innitial value of covariance matrix
newidentity( j, j) = 1.0*(0.01)/dimen
end do
print *, newidentity
call random_number(harvest1)
seed_in1 = aint(harvest1 * 2.0e0**31)
meanvectnorm(1,1) = 0.2
meanvectnorm(2,1) = 0.3
meanvectnorm(3,1) = 0.001
!print *, meanvectnorm
meanvectnormtrans = transpose(meanvectnorm)
! call spotrf('U', dimen, newidentity)
!call potrf( newidentity, 'U')
! note that since cholesky decomposition of newidentity does not change, since newidentity does not change one only needs to derive it once
newidentity2 = 0.0
do i = 1, dimen
do j = 1, dimen
if (i .ge. j) then
newidentity2(i,j) = newidentity(i,j)
end if
end do
end do
print *, newidentity2
print *, "test"
call gaussianmv_rng_mkl(seed_in1, n_rand_obs_in, r_mvgaussian_list2, dimen, meanvectnormtrans, newidentity2)
!subroutine gaussianmv_rng_mkl(seed_in, n_rand_obs_in, r_mvgaussian_list, dimen, mean, tcv)
do i = 1, n_rand_obs_in
do j = 1, dimen
print *, r_mvgaussian_list2(i, j)
end do
end do
end program
which in turns calls the subroutine that I have created to use mutlivariate random numbers,
use :: mkl_vsl_type
integer :: brng
real, pointer, intent(out) :: r_mvgaussian_list
type(VSL_STREAM_STATE) :: stream
integer :: status, methodrng
external :: vslnewstream, vsrnggausianmv, vsldeletestream
methodrng = VSL_RNG_METHOD_GAUSSIANMV_BOXMULLER
mstorage = VSL_MATRIX_STORAGE_FULL
brng = vsl_brng_mcg31
status = vslnewstream(stream, brng, seed_in)
status = vsrnggaussianmv( methodrng, stream, n_rand_obs_in, r_mvgaussian_list, dimen, mstorage, mean, tcv)
status = vsldeletestream(stream)
end subroutine
yuriisig
see ....\mkl\examples\vslf
mecej4
You have a large number of errors with respect to argument types in your sample code. To catch such errors at compile time rather than experiencing run-time aborts, use IMPLICIT NONE, use all available interface modules, and use /warn:all as a compiler option. Finally, note that one of the worst things you can do is to give the compiler an incorrect interface block.
The documentation clearly states that you need to supply the Cholesky factor T of the variance-covariance matrix as an argument.
There is also a functioning example, vsrnggaussianmv.f, provided in the MKL examples directory. The example shows the call the call to the Cholesky factorization routine spotrf.
