Handling of duplicates in COO matrices
cpmech
Does Intel MKL sum up duplicates when converting COO matrices to CSR matrices via mkl_sparse_convert_csr? (This essential information is missing from the web documentation...)
noffermans
Yes, mkl_sparse_convert_csr performs a sum reduction on duplicates.
This can be easily verified with a simple example:
#define M      2
#define N      2
#define NNZ    3
      MKL_INT m = M, n=N, nnz=NNZ;
      MKL_INT ia_coo[NNZ] = {0, 0, 1};
      MKL_INT ja_coo[NNZ] = {0, 0, 0};
      double a_coo[NNZ] = {1.0, 2.0, 3.0};
      sparse_matrix_t Acoo;
      sparse_status_t status_create = mkl_sparse_d_create_coo(&Acoo, 0, m, n, nnz, ia_coo, ja_coo, a_coo);
      printf("Status create : %d\n", status_create);
      sparse_matrix_t Acsr;
      sparse_status_t status_convert = mkl_sparse_convert_csr (Acoo, SPARSE_OPERATION_NON_TRANSPOSE, &Acsr);
      printf("Status convert : %d\n", status_convert);
      sparse_index_base_t indexing;
      MKL_INT *iab_csr, *iae_csr, *ja_csr;
      double *a_csr;
      sparse_status_t status_export = mkl_sparse_d_export_csr(Acsr, &indexing, &m, &n, &iab_csr, &iae_csr, &ja_csr, &a_csr);
      printf("Status export : %d\n", status_export);
      MKL_INT i, j;
      printf("Matrix converted to CSR format:\n");
      for (i=0; i<m; i++) {
          MKL_INT jab=iab_csr[i]-indexing, jae=iae_csr[i]-indexing;
          for (j=jab; j<jae; j++) {
              MKL_INT col = ja_csr[j];
              printf("  A[%lld, %lld] = %lf\n", i+indexing, col, a_csr[j]);
Hope this helps.
Best,
Nicolas
noffermans
#define M      2
#define N      2
#define NNZ    3
      double *a_csr;
      MKL_INT i, j;
Hope this helps.
Best,
Nicolas
cpmech
Hi, thank you, much appreciated! I'm wondering if we can have the (web) documentation updated with this information so our reviewing/quality-control team can accept our pull-requests more easily. Best, Doriv4l.
ShanmukhS_Intel
It’s great to know that the issue has been resolved, in case you run into any other issues please feel free to create a new thread
Sure, We will inform the concerned team regarding the documentation update. Thank you for your valuable suggestions.
Shanmukh.SS
noffermans
Hi Doriv4l,
Yes, great that your issue is resolved! I can confirm that the Developer Reference will be updated. It might take a while before the change is visible on the webpage though.
Thanks for the feedback, it's always appreciated.
Nicolas
