7298 Discussions
Help on how to use included examples on Mac
CO_Traut
I installed ifort compiler for Mac OS* X which comes with mkl lib. Then I want to test the compiler and mkl lib with an example in the folder/opt/intel/Compiler/11.1/058/Frameworks/mkl/examples/fftw2xf. However, error information shows up as what follows. Could you let me know what's wrong with me?
make lib32
make wrap_lib _IA=32
cd "../.."/interfaces/fftw2xf && make lib32 PRECISION=MKL_DOUBLE compiler=intel INSTALL_DIR=/opt/intel/Compiler/11.1/058/Frameworks/mkl/examples/fftw2xf/lib/32
make clean libfftw2xf_intel.a _IA=32
rm -rf /opt/intel/Compiler/11.1/058/Frameworks/mkl/examples/fftw2xf/lib/32/obj
rm -f /opt/intel/Compiler/11.1/058/Frameworks/mkl/examples/fftw2xf/lib/32/libfftw2xf_intel.a
mkdir -p /opt/intel/Compiler/11.1/058/Frameworks/mkl/examples/fftw2xf/lib/32/obj
mkdir: /opt/intel/Compiler/11.1/058/Frameworks/mkl/examples/fftw2xf/lib: Permission denied
make[3]: *** [libfftw2xf_intel.a] Error 1
make[2]: *** [lib32] Error 2
make[1]: *** [wrap_lib] Error 2
make: *** [lib32] Error 2
Yuan_C_Intel
Quoting - CO_Traut
The error shows that you don't have permission to mkdirunder folder"/opt/intel/Compiler/11.1/058/Frameworks/mkl/examples/fftw2xf/lib". So have a check on youraccountaccess permissions for the installation folder and reset the permission if needed.
CO_Traut
Thanks much. I changed the permission to the entire folder of /mkl and reran the code. Now I get error msg like this. Seems like 'icc' is required, but I am using ifort instead of icc... I am confused.
c-71-56-196-131:fftw2xf liangzhezhang$ make lib32
make -f makefile objects
icc -c -DMKL_DOUBLE -I../../include -I../../include/fftw wrappers/fftw_f77.c -o /opt/intel/Compiler/11.1/058/Frameworks/mkl/examples/fftw2xf/lib/32/obj/fftw_f77.o
make[4]: icc: Command not found
make[4]: *** [/opt/intel/Compiler/11.1/058/Frameworks/mkl/examples/fftw2xf/lib/32/obj/fftw_f77.o] Error 127
make[3]: *** [libfftw2xf_intel.a] Error 2
eliosh
Quoting - CO_Traut
From what I see, You try to build wrappers that provide FFTW interface to Intel's own FFT routines. The wrappers are written in C not in Fortran. I do not know much about Mac version, but PC version of MKL, if I remember correctly, comes with precompiled interfaces that you can uses from Fortran programs. Check the manual.
CO_Traut
Quoting - eliosh
Thanks for your help.
I read through the manual... but I am so confused. The manual command is not consistent with the examples that come with the compiler package.
Steven_L_Intel1
I'm going to move this discussion to the MKL forum.
Ying_H_Intel
Hello CO_Traut,
Yes, as eliosh mentioned, the FFT warpper iswritten by C, so it requiresa C compiler on your machine. the command > make lib32 will invoke Intel C compiler to build the warpper library.But you haven't Intel C Compiler, so build failed.
Attached is one I build. Please copy it into your MKL library library for example,
/opt/intel/Compiler/11.1/058/Frameworks/mkl/lib/32
Then you can use it in the future.
For build the example code under example/fftw2xf,
You may try the command.
for example build real 1d FFT.
>ifort -w -vec-report0 -DMKL_DOUBLE -I"/opt/intel/Compiler/11.1/058/Frameworks/mkl"/include -I"/opt/intel/Compiler/11.1/058/Frameworks/mkl"/include/fftw source/real_1d_double_ex2.f source/mkl_fftw_examples_support.f -L/opt/intel/Compiler/11.1/058/Frameworks/mkl/lib/32 -lfftw2xf_intel "/opt/intel/Compiler/11.1/058/Frameworks/mkl/lib/32"/libmkl_intel.a "/opt/intel/Compiler/11.1/058/Frameworks/mkl/lib/32"/libmkl_intel_thread.a "/opt/intel/Compiler/11.1/058/Frameworks/mkl/lib/32"/libmkl_core.a -L"/opt/intel/Compiler/11.1/058/lib" -liomp5 -lpthread -lm -o _results/intel_parallel_32_lib_double/real_1d_double_ex2.out
and run the executable file,
Hope it helps
Ying
