7303 Discussions
How can I remove a column from a sparse matrix (CSR) using MKL
rdees
I need to revove a column from a large sparse matrix that is stored in CSR format, using MKL.  I cannot find an MKL routine that does this directly.  Can anyone tell me how it can be done?   I'm using Fortran.  Thx.  Bob
mecej4
Here is similar code for an unsymmetric, non-square matrix. The matrix is 7 X 8 and column-3 is deleted, giving a 7 X 7 matrix.
mecej4
Here is an example where the input 8 X 8 matrix is symmetric and only the upper triangle is processed. The example shows the third column being deleted. The call to mkl_ddnscsr() is only for printing purposes, and is not needed for the column deletion.
[NOTE: The program listing is portrayed by the formatter as double spaced. That was not intended, and I request the Intel people to tell me how to avoid such unintended double spacing.]
[fortran]       PROGRAM pardiso_sym
      IMPLICIT NONE
C.. All other variables
      INTEGER maxfct, mnum, mtype, phase, n, nrhs, error, msglvl
      INTEGER iparm(64)
      INTEGER ia(9),ian(9)
      INTEGER ja(18)
      REAL*8 a(18),ad(8,7)
      REAL*8 b(8)
      REAL*8 x(8)
      INTEGER i, j,k,kn, idum,job(6), info, jdel
      REAL*8 waltime1, waltime2, ddum
C.. Fill all arrays containing matrix data.
      DATA n /8/, nrhs /1/, maxfct /1/, mnum /1/
      DATA ia /1,5,8,10,12,15,17,18,19/
      DATA ja
     1 /1,  3,    6,7,
     2    2,3,  5,
     3      3,        8,
     4        4,    7,
     5          5,6,7,
     6            6,  8,
     7              7,
     8                8/
      DATA a
     1 /7.d0,     1.d0,          2.d0,7.d0,
     2       -4.d0,8.d0,     2.d0,
     3            1.d0,                    5.d0,
     4                 7.d0,     9.d0,
     5                      5.d0,1.d0,5.d0,
     6                           -1.d0,     5.d0,
     7                                11.d0,
     8                                     5.d0/
c
c  Drop column 3
c
      data job/1,1,1,0,0,0/
c
      jdel = 3                     ! column to delete
      kn = 0
      ian(1)=1
      do i=1,n
         do k=ia(i),ia(i+1)-1      ! row i
            if(ja(k).ne.jdel)then
               kn=kn+1
               if(ja(k).gt.jdel)then
                  ja(kn)=ja(k)-1
               else
                  ja(kn)=ja(k)
               endif
               a(kn)=a(k)
            endif
         end do
         ian(i+1)=kn+1
      end do
c
      do i=1,n
         write(*,'(7(2x,I2,1x,F10.3))')(ja(j),a(j),j=ian(i),ian(i+1)-1)
      end do
      write(*,*)
      call mkl_ddnscsr(job,n,n-1,ad,n,a,ja,ian,info)
      write(*,*)'info = ',info
      do i=1,n
         write(*,'(7F10.3)')(ad(i,j),j=1,7)
      end do
      END[/fortran]
mecej4
Here is an example that shows how to perform the column deletion that you sought. I show how to delete a column in a symmetric matrix represented by only its upper triangular part. Please note that the call to mkl_ddnscsr() is not needed for the column deletion, but to facilitate printing the modified matrix.
[Note to Forum Moderators: My first response (#2) was held up for approval for several hours. Then, after it was approved, I noticed that the inline code was formatted with double spacing, and added a couple of sentences to #2 to disclaim that I had inserted the extra blank lines. When I did the edits and clicked "SUBMIT", the whole of #2 evaporated, and the forum TOC showed the number of replies as 0. In response to this event, I posted #3. Subsequently, #2 appeared again. There is much duplication between the two: readers please note this!]
rdees
mecej4,  Thx so much.  It works great.  Do you happen to have a version of this code that would work on an non-symmetric, sparse matrix.  If you do, that would be very helpful too.
mecej4
rdees
meje4 - Thx again - It works great - I appreciate your help.
rdees
Thanks again for helping me with this.  You have been very helpful.
