How prevent termination due to Zero Pivot?
A_B_
I use DSS interface to solve a  sparse symmetric linear system. When a matrix is singular,  the code is terminated at dss_factor_real() with a message  "MKL-DSS-DSS-Error, Zero Pivot detected".  It is inconvenient if I have to do it many times.
How do I prevent the termination  and instead check whether factorization was successful.
Is this controlled  by option=MKL_DSS_TERM__LVL_ERROR? I tried to change it but  nothing happened.
Thank you.
Alexander_K_Intel2
It is look like you set that your matrix is positive defined that guarantee absence of pivot during factorization. Just change type of matrix on non-positive define.
Alex
A_B_
Thanks,  changing matrix type to MKL_DSS_INDEFINITE it has removed the termination. However, now, even if the matrix is singular, the error of dss_factor_real  and dss_solve_real  is MKL_DSS_SUCCESS.     I guess I am getting just one of many possible solutions.
Is there a way to tell that matrix was singular and the result should be discarded? Thank you.
Gennady_F_Intel
there are no such opportunity in Pardiso.
