7302 Discussions
How to compile the example C# wrapper on a 64bit server to call DGEMM
srlawton
Hi, I'm really stuck.
I have previously successfully compiled the Example C# wrapper to call DGemm on a 32 bit machine, creating MKL.DLL - C# wrapper which calls the Intel MKL DLLs
The following command worked just fine:
nmake ia32 mklroot="C:\\\\Program Files\\\\Intel\\\\MKL\\\\10.2.1.019"
I have now moved to an Intel 64 bit server and have installed Visual Studio 2008 SP1.
From a Visual Studio 2008 Command Prompt on the 64 bit machine (Windows 2003 Server)
Upon calling:
C:\\\\Temp\\\\Intel_MKL_C#_Examples>nmake ia64 MKLROOT="c:\\\\program files\\\\intel\\\\mkl\\\\10.2.0.014\\\\"
I get:
Microsoft Program Maintenance Utility Version 9.00.30729.01
Copyright (C) Microsoft Corporation. All rights reserved.
Add path of the MKL libraries to the lib environment variable
set lib=%MKLROOT%\\\\ia64\\\\lib;%lib%
MKL entries for custom dll
Workaround for pardiso
Microsoft 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
_fseeki64.c
Build MKL custom dll
nmake mkl.dll MACHINE=IA64 MKL_LIB="mkl_intel_lp64_dll.lib mkl_intel_thread_dll.lib mkl_core_dll.lib" MSLIB="msvcrt.lib user32.lib"
link /DLL /MACHINE:IA64 /def:user.def _fseeki64.obj mkl_intel_lp64_dll.lib mkl_intel_thread_dll.lib mkl_core_dll.lib libiomp5md.lib msvcrt.lib user32.l
ib /out:mkl.dll
Microsoft Incremental Linker Version 9.00.30729.01
_fseeki64.obj : fatal error LNK1112: module machine type 'X86' conflicts with target machine type 'IA64'
NMAKE : fatal error U1077: '"E:\\\\Program Files (x86)\\\\Microsoft Visual Studio 9.0\\\\VC\\\\BIN\\\\link.EXE"' : return code '0x458'
Stop.
NMAKE : fatal error U1077: '"E:\\\\Program Files (x86)\\\\Microsoft Visual Studio 9.0\\\\VC\\\\BIN\\\\nmake.EXE"' : return code '0x2'
Stop.
My paths seem Ok:
echo %lib%
"C:\\\\Program Files\\\\Intel\\\\MKL\\\\10.2.0.014\\\\ia64\\\\lib"
echo %MKLRoot%
it seems to be failing at the end: module machine type 'X86' conflicts with target machine type 'IA64'.
Any ideas how I can get a 64 bit version of the DLL built ?
Thanks in advance
Steve
Gennady_F_Intel
Stephen, i guess your target mashine type is not 'IA64' ( aka Itanium), but 'em64t' ( aka Xeon).
So, add path of the MKL libraries to the lib environment variableset lib=%MKLROOT%\\em64t\\lib;%lib%, instead of%MKLROOT%\\ia64\\lib;%lib%
--Gennady
Gennady_F_Intel
--Gennady
Gennady_F_Intel
Just for your information - please look at the KB article explains whatIA-32, Intel 64 and IA-64 Architecture means
srlawton
Gennady, thanks.
I've made life difficult for myself today.
Advice to everyone, when installing Visual Studio 2008, select "Full" install not "Default", this gives you the x64 bit compiler + 64 bit V Studio Command Prompt. It may take a bit longer to install but atleast you will have the full suite.
Everything works once you have the right software installed.
regards,
Steve
