7303 Discussions
How to improve accuracy of solution given by mkl PARDISO?
chdthanh
Dear all,
I am using mkl PARDISO to solve A*x=b with default parameters iparm(1)=0.
From solution x1 given by PARDISO, I compute b1= A*x1. Norm of error (b1-b) is about 1E-2. Do you know how to improve this error more, for example 1E-6?
Thanh
Sergey_Solovev__Inte
Dear, Thanh,
please, set iparm() manually (iparm(1)=1). Try to use iterative refinement step - iparm(8)=1. iparm(8) should be set to the maximum number of iterative refinement steps that the solver will perform.
Gennady_F_Intel
but it might be not help in the case of ill-conditioned matrices
