7303 Discussions
How to install oneMKL in GitHub Actions?
hmenke
I'm trying to use oneMKL in GitHub Actions and I have stumbled upon https://github.com/oneapi-src/oneapi-ci which provides an example how to install DPCPP inside GitHub Actions. To this end I simply copied the script into my workflow file and essentially replaced COMPONENTS=intel.oneapi.win.dpcpp-compiler with COMPONENTS=intel.oneapi.win.mkl.devel:intel.oneapi.win.tbb.devel:intel.oneapi.win.dpl.
on: [ push ]
jobs:
  build:
    runs-on: windows-2019
    steps:
      # https://github.com/oneapi-src/oneapi-ci/blob/master/scripts/install_windows.bat
      - name: Install Intel oneAPI Math Kernel Library (oneMKL)
        shell: cmd
        run: |
           on
          REM SPDX-FileCopyrightText: 2022 Intel Corporation
          REM
          REM SPDX-License-Identifier: MIT
          set URL=https:/registrationcenter-download.intel.com/akdlm/IRC_NAS/c961e083-5685-4f0b-ada5-c6cf16f561dd/w_BaseKit_p_2023.1.0.47256_offline.exe
          set COMPONENTS=intel.oneapi.win.mkl.devel:intel.oneapi.win.tbb.devel:intel.oneapi.win.dpl
          curl.exe --output %TEMP%\webimage.exe --url %URL% --retry 5 --retry-delay 5
          start /b /wait %TEMP%\webimage.exe -s -x -f webimage_extracted --log extract.log
          del %TEMP%\webimage.exe
          webimage_extracted\bootstrapper.exe -s --action install --components=%COMPONENTS% --eula=accept -p=NEED_VS2017_INTEGRATION=0 -p=NEED_VS2019_INTEGRATION=0 -p=NEED_VS2022_INTEGRATION=0 --log-dir=.
          set installer_exit_code=%ERRORLEVEL%
          rd /s/q "webimage_extracted"
          exit /b %installer_exit_code%
However, the installer never finished. bootstrapper.exe just sits there for multiple hours without any output until GitHub kills the run. Can you please tell me what I'm doing wrong?
I've also reported this as an issue on the oneapi-ci repo: https://github.com/oneapi-src/oneapi-ci/issues/71
hmenke
Oof, turned out the culprit was the environment variable QT_QPA_PLATFORM="offscreen" (which I had omitted in my example and therefore was not able to reproduce the issue)
hmenke
George_Silva_Intel
Thank you so much for reaching Intel and for sharing the solution for your issue. The oneMKL users will benefit from your contribution.
PraneethA_Intel
Hi Henri,
Thanks for posting in Intel communities.
Glad to know your issue is resolved. Thanks for sharing the solution with us. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
Praneeth Achanta
