How to link the solver PARDISO
caoyuxin541
Hello everyoneThis is my problemI need a help
I want to use Pardisobut there is a error"fatal error LNK1000: unknown error; consult documentation for technical support options"
compilerVC6++
I specified the paths to mkl_core.lib mkl_solver_sequential.lib mkl_lapack.lib mkl_c.lib mkl_solver.lib mkl_c_dll.lib mkl_cdft.lib mkl_intel_c.lib mkl_intel_thread.lib , but it doesn't work =(. What's wrong? May be MKL is not compatible with CVF6.6c I'm using?
This is my code
#include
#include
#include
#include "mkl_pardiso.h"
#include "mkl.h"
#include "mkl_lapack.h"
#include "mkl_scalapack.h"
extern int omp_get_max_threads();
extern int PARDISO
(void *, int *, int *, int *, int *, int *,
double *, int *, int *, int*, int *, int *,
int *, double *, double *, int*);
main( )
int n = 8;
int ia[ 9] = { 1, 5, 8, 10, 12, 15, 17, 18, 19 };
int ja[18] = { 1, 3, 6, 7,
2, 3, 5,
3, 8,
4, 7,
5, 6, 7,
6, 8,
7,
8 };
double a[18] = { 7.0, 1.0, 2.0, 7.0,
-4.0, 8.0, 2.0,
1.0, 5.0,
7.0, 9.0,
5.0, 1.0, 5.0,
-1.0, 5.0,
11.0,
5.0 };
int mtype = -2;
double b[8], x[8];
int nrhs = 1;
void *pt[64];
int iparm[64];
int maxfct, mnum, phase, error, msglvl;
int i;
double ddum; /* Double dummy*/
int idum; /* Integer dummy.*/
/* .. Setup Pardiso control parameters.*/
for (i = 0; i < 64; i++) {
iparm = 0;
iparm[0] = 1; /* No solver default*/
iparm[1] = 2; /* Fill-in reordering from METIS */
/* Numbers of processors, value of MKL_NUM_THREADS */
iparm[2] = 2;
/*mkl_get_max_threads()*/
iparm[3] = 0; /* No iterative-direct algorithm */
iparm[4] = 0; /* No user fill-in reducing permutation */
iparm[5] = 0; /* Write solution into x */
iparm[6] = 16; /* Default logical fortran unit number for output */
iparm[7] = 2; /* Max numbers of iterative refinement steps */
iparm[8] = 0; /* Not in use*/
iparm[9] = 13; /* Perturb the pivot elements with 1E-13 */
iparm[10] = 1; /* Use nonsymmetric permutation and scaling MPS */
iparm[11] = 0; /* Not in use*/
iparm[12] = 0; /* Not in use*/
iparm[13] = 0; /* Output: Number of perturbed pivots */
iparm[14] = 0; /* Not in use*/
iparm[15] = 0; /* Not in use*/
iparm[16] = 0; /* Not in use*/
iparm[17] = -1; /* Output: Number of nonzeros in the factor LU */
iparm[18] = -1; /* Output: Mflops for LU factorization */
iparm[19] = 0; /* Output: Numbers of CG Iterations */
maxfct = 1; /* Maximum number of numerical factorizations. */
mnum = 1; /* Which factorization to use. */
msglvl = 0; /* Don't print statistical information in file */
error = 0; /* Initialize error flag */
/* .. Initialize the internal solver memory pointer. This is only */
/* necessary for the FIRST call of the PARDISO solver. */
pt = 0;
/* .. Reordering and Symbolic Factorization. This step also allocates */
/* all memory that is necessary for the factorization. */
phase = 11;
PARDISO (pt, &maxfct, &mnum, &mtype, &phase,
&n, a, ia, ja, &idum, &nrhs,
iparm, &msglvl, &ddum, &ddum, &error);
if (error != 0) {
printf("\\nERROR during symbolic factorization: %d", error);
exit(1);
printf("\\nReordering completed ... ");
printf("\\nNumber of nonzeros in factors = %d", iparm[17]);
printf("\\nNumber of factorization MFLOPS = %d", iparm[18]);
/* .. Numerical factorization.*/
phase = 22;
if (error != 0) {
printf("\\nERROR during numerical factorization: %d", error);
exit(2);
printf("\\nFactorization completed ... ");
/* .. Back substitution and iterative refinement. */
phase = 33;
iparm[7] = 2; /* Max numbers of iterative refinement steps. */
/* Set right hand side to one.*/
for (i = 0; i < n; i++) {
b = 1;
iparm, &msglvl, b, x, &error);
if (error != 0) {
printf("\\nERROR during solution: %d", error);
exit(3);
printf("\\nSolve completed ... ");
printf("\\nThe solution of the system is: ");
printf("\\n x [%d] = % f", i, x );
printf ("\\n");
/* .. Termination and release of memory. */
phase = -1; /* Release internal memory. */
&n, &ddum, ia, ja, &idum, &nrhs,
return 0;
thank you
Gennady_F_Intel
the duplicated to this issue
ArturGuzik
Valued Contributor I
Gennady,
I think you can just delete this one.
A.
