7264 Discussions
How to multiply each row of matrix by a single column in CBLAS
Pinkerton__James
I'd like to do the following in CBLAS:
static float a[max_i][max_j];
static float b[max_i][max_j];
static float vec[max_i];
for (size_t i = 0; i < max_i; i++) {
  for (size_t j = 0; j < max_j; j++) {
    b += vec * a;
Is there a single performant function that I can use to do this whole thing (assuming I alter the 2d arrays to be 1d arrays)? I know I can do this with a for loop of cblas_saxpy's.
Thanks!
Ying_H_Intel
Hi James,
​It seems no one blas function can do this.  Maybe you can take vec as diagonal element of one matrix, other as 0, then call gemm. B=A*V+B
​Ying
