- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Hi there,
I have a program which will randomly generate cases with linear equations to be solved. For most of the cases, the linear equations will be sparse. So I use the DSS to solve them. But when it involves a full matrix problem.The DSS will stack at the dss_reorder and shows forrtl: severe (157): Program Exception -access violation.
Can anyone tell me how to fix this problem in an efficient way? I don't want to add too much codes to check if the matrix is full and add additional routine for the full matrix case.
The attached is my test case for the full matrix problem. Your help will be greatly appreciated.
Thanks!
Tianyu
PROGRAM Test
INCLUDE 'mkl_dss.f77'
INTEGER tIU(:), tJU(:), Idum(:), ITER
DOUBLE PRECISION tUM(:), tXDIFF(:), tX(:)
ALLOCATABLE tIU, tJU, tUM, tXDIFF, tX, Idum
INTEGER nNonZeros,nRow
INTEGER*8 handle
INTEGER error
!OPEN (UNIT=10, FILE='testInfo.dat')
!READ (10,7004) nNonZeros, nRow
!CLOSE(10)
nRow=2
nNonZeros=4
ALLOCATE(tIU(nRow+1))
ALLOCATE(tXDIFF(nRow))
ALLOCATE(tX(nRow))
ALLOCATE(tJU(nNonZeros))
ALLOCATE(tUM(nNonZeros))
ALLOCATE(Idum(nRow))
tJU(1)=1
tJU(2)=2
tJU(3)=1
tJU(4)=2
tIU(1)=1
tIU(2)=3
tIU(3)=5
tUM(1)=0.0751
tUM(2)=0.0116
tUM(3)=0.0116
tUM(4)=-0.0751
tXDIFF(1)=1
tXDIFF(2)=0
!OPEN (UNIT=10, FILE='columns.dat')
!READ (10,7002) (tJU(II),II=1,nNonZeros)
!CLOSE(10)
!OPEN (UNIT=10, FILE='rowIndex.dat')
!READ (10,7002) (tIU(II),II=1,nRow+1)
!CLOSE(10)
!OPEN (UNIT=10, FILE='values.dat')
!READ (10,7001) (tUM(II),II=1,nNonZeros)
!CLOSE(10)
!OPEN (UNIT=10, FILE='loadVector.dat')
!READ (10,7001) (tXDIFF(II),II=1,nRow)
!CLOSE(10)
ITER=1
C---------------------------------------------------------------------------
C Initialize the solver
error = dss_create(handle, MKL_DSS_DEFAULTS+MKL_DSS_OOC_VARIABLE)
IF (error .NE. MKL_DSS_SUCCESS ) GOTO 999
C Define the non-zero structure of the matrix
! error = dss_define_structure( handle, MKL_DSS_SYMMETRIC,
!& tIU, nRow, nRow, tJU, nNonZeros )
error = dss_define_structure( handle, MKL_DSS_NON_SYMMETRIC,
C Reorder the matrix
IF (ITER.EQ.1) THEN
error = dss_reorder( handle, MKL_DSS_GET_ORDER, Idum)
ELSE
error = dss_reorder( handle, MKL_DSS_MY_ORDER, Idum)
ENDIF
C Factor the matrix
error = dss_factor_real( handle, MKL_DSS_DEFAULTS, tUM)
C Get the solution vector
error = dss_solve_real( handle, MKL_DSS_DEFAULTS,
& tXDIFF, 1, tX)
C Deallocate solver storage
error = dss_delete( handle, MKL_DSS_DEFAULTS )
OPEN (UNIT=10, FILE='OutValues.dat')
WRITE (10,7005) (tX(II),II=1,nRow)
CLOSE(10)
GOTO 1999
7001 FORMAT(1X,D)
7002 FORMAT(1X,I5)
7003 FORMAT(1X,I,1X,D)
7004 FORMAT(1X,I,1X,I)
7005 FORMAT(1X,D)
999 WRITE(*,*) "Solver returned error code ", error
1999 DEALLOCATE(tIU,tJU,tUM,tXDIFF,tX,Idum)
END
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
it really failed with version 11.0. Checking with the latest MKL v.11.3.3, I don't see problem - below the output ( I slightly modified the code by adding error status and mkl version )
Intel(R) Math Kernel Library Version 11.3.3 Product Build 20160413 for Intel(R) 64 architecture applications
(1)...dss_create == 0
(2)...dss_define_structure == 0
(3)...dss_reoder == 0
(4) ...dss_factor_real == 0
(5)...dss_solve_real == 0
(6)...dss_delete == 0
the updates file is also attached.
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Tianyu, thanks for report. What MKL version do you use?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Gennady, I am using MKL 11.0.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thanks Gennady.
Actually, I have extended the full matrix into a sparse matrix by adding one more row and of course one more column as well. In that way, DSS in MKL 11.0 works.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
