7303 Discussions
How to use library to create a power spectrum
Glowlink_Glowlink
I'm new to the Math Kernal Library.
Are there any examples that show how to to take a set to complex data and convert it to a power spectrum
thx
ArturGuzik
Valued Contributor I
I might be wrong but in MKL itself you'll need to use FFT routines and obtain it yourself. However, as far as I can remember, in IPP library there is PowerSpectr function which takes complex vector and computes its power spectrum in single call.
A.
Gennady_F_Intel
as usual Artur is right. :). Yes. Please see into IPP signal processing domain / Conversion Functions:
you can find such functions for double, float and short complex data types:
as an example
IppStatus ippsPowerSpectr_64fc(const Ipp64fc* pSrc, Ipp64f* pDst, int len);
where 64fc ( in IPP notation) == double complex ( MKL notation).
--Gennady
Dmitry_B_Intel
Given the spectrum y=fft(x), power spectrum of x is ps=y*conj(y), the computation can be done with a simple loop readily vectorizable bycompiler, or with a call to MKL VML function, like this:
vcMulByConj(n,y,y,ps)
Dima
