Using Pardiso in a dll
jpharvey1981
I am using the Pardiso routine in a dll (The code is a copy/paste from the pardiso_sym_f.f available in the example folder of mkl... I just removed theWRITE statements)and I get the following error message on compilation:
...The type of the actual argument differs from the type of the dummy argument...
However, when using the exact same code in a console application, there are no error messages, I can run the application, see the results, etc.
Why am I not able to compile my dll while the exact same code in an application console is working properly?
Ying_H_Intel
Hello jpharvel,
How do you call the Pardiso Routine in a dll? Could you attached a small test case?
According tothe error message, I check in Intel Fortran compiler forum, http://software.intel.com/en-us/forums/showthread.php?t=61735. The problem seems hint itself. There is parameter ormodule, which actual argument is diff from the dummy arguments.
Other discussion like http://coding.derkeiler.com/Archive/Fortran/comp.lang.fortran/2005-10/msg00640.html
BestRegards,
Ying
jpharvey1981
Dear Ying,
I tried to reproduce the error message that I got yesterday but now the code can be compiledproperly...
I honestly does not have any clues how I made it work...
Here is the test code for the dll:
subroutine test()
!DEC$ ATTRIBUTES DLLEXPORT :: test
!DEC$ ATTRIBUTES STDCALL :: test
!DEC$ ATTRIBUTES REFERENCE :: test
C.. Internal solver memory pointer for 64-bit architectures
C.. INTEGER*8 pt(64)
C.. Internal solver memory pointer for 32-bit architectures
C.. INTEGER*4 pt(64)
C.. This is OK in both cases
INTEGER*8 pt(64)
C.. All other variables
INTEGER maxfct, mnum, mtype, phase, n, nrhs, error, msglvl
INTEGER iparm(64)
INTEGER ia(9)
INTEGER ja(18)
REAL*8 a(18)
REAL*8 b(8)
REAL*8 x(8)
INTEGER i, idum
REAL*8 waltime1, waltime2, ddum
C.. Fill all arrays containing matrix data.
DATA n /8/, nrhs /1/, maxfct /1/, mnum /1/
DATA ia /1,5,8,10,12,15,17,18,19/
DATA ja
1 /1, 3, 6,7,
2 2,3, 5,
3 3, 8,
4 4, 7,
5 5,6,7,
6 6, 8,
7 7,
8 8/
DATA a
1 /7.d0, 1.d0, 2.d0,7.d0,
2 -4.d0,8.d0, 2.d0,
3 1.d0, 5.d0,
4 7.d0, 9.d0,
5 5.d0,1.d0,5.d0,
6 -1.d0, 5.d0,
7 11.d0,
8 5.d0/
C..
C.. Set up PARDISO control parameter
C..
do i = 1, 64
iparm(i) = 0
end do
iparm(1) = 1 ! no solver default
iparm(2) = 2 ! fill-in reordering from METIS
iparm(3) = 1 ! numbers of processors
iparm(4) = 0 ! no iterative-direct algorithm
iparm(5) = 0 ! no user fill-in reducing permutation
iparm(6) = 0 ! =0 solution on the first n compoments of x
iparm(7) = 0 ! not in use
iparm(8) = 9 ! numbers of iterative refinement steps
iparm(9) = 0 ! not in use
iparm(10) = 13 ! perturbe the pivot elements with 1E-13
iparm(11) = 1 ! use nonsymmetric permutation and scaling MPS
iparm(12) = 0 ! not in use
iparm(13) = 0 ! maximum weighted matching algorithm is switched-off (default for symmetric). Try iparm(13) = 1 in case of inappropriate accuracy
iparm(14) = 0 ! Output: number of perturbed pivots
iparm(15) = 0 ! not in use
iparm(16) = 0 ! not in use
iparm(17) = 0 ! not in use
iparm(18) = -1 ! Output: number of nonzeros in the factor LU
iparm(19) = -1 ! Output: Mflops for LU factorization
iparm(20) = 0 ! Output: Numbers of CG Iterations
error = 0 ! initialize error flag
msglvl = 1 ! print statistical information
mtype = -2 ! symmetric, indefinite
C.. Initiliaze the internal solver memory pointer. This is only
C necessary for the FIRST call of the PARDISO solver.
do i = 1, 64
pt(i) = 0
end do
C.. Reordering and Symbolic Factorization, This step also allocates
C all memory that is necessary for the factorization
phase = 11 ! only reordering and symbolic factorization
CALL PARDISO (pt, maxfct, mnum, mtype, phase, n, a, ia, ja,
1 idum, nrhs, iparm, msglvl, ddum, ddum, error)
WRITE(*,*) 'Reordering completed ... '
IF (error .NE. 0) THEN
WRITE(*,*) 'The following ERROR was detected: ', error
STOP 1
END IF
WRITE(*,*) 'Number of nonzeros in factors = ',iparm(18)
WRITE(*,*) 'Number of factorization MFLOPS = ',iparm(19)
C.. Factorization.
phase = 22 ! only factorization
CALL pardiso (pt, maxfct, mnum, mtype, phase, n, a, ia, ja,
WRITE(*,*) 'Factorization completed ... '
STOP 1
ENDIF
C.. Back substitution and iterative refinement
iparm(8) = 2 ! max numbers of iterative refinement steps
phase = 33 ! only factorization
do i = 1, n
b(i) = 1.d0
end do
1 idum, nrhs, iparm, msglvl, b, x, error)
WRITE(*,*) 'Solve completed ... '
WRITE(*,*) 'The solution of the system is '
DO i = 1, n
WRITE(*,*) ' x(',i,') = ', x(i)
END DO
C.. Termination and release of memory
phase = -1 ! release internal memory
CALL pardiso (pt, maxfct, mnum, mtype, phase, n, ddum, idum, idum,
END
I was also able to use successfully a similar dll in my delphi project so sorry about my thread!
thank you for your attention
abhimodak
Hello jpharvey1981
A remote remote chance, but perhaps were you using /gen-interfaces and /warn-interfaces? If so, did you make any modifications in the interface of the subroutines? If so, did you happen to do a "clean" project before you built it again?
Hope this is not too much a digression.
Abhi
jpharvey1981
The major problem when using Microsoft Visual Studio is thatyou loose the knowledge ofthe command lines sent to the intel fortran compiler. I am an occasional user of the intel visual fortran compiler and I am not taking care of the command lines sent to the compiler...unfortunately.
I did start aproject from scratch (clean project)this morning, knowing exactly how to solve the problematic (after a long night of trials and errors I managed to use the mkl_pardiso.f90 version)...
JP
