I can't use oneMKL on visual studio
k_higashi
When I set Use oneMKL= Sequential in the Intel Libraries for oneAPI on Visual studio project property, I couldn't run the build.
I waited about 10 minutes after starting the build.
However, the build did not finish with the following displayed on the Output screen.
Rebuild started...
1>------ Rebuild All started: Project: TestOneMKL, Configuration: Release x64 ------
I attach a file that can verify this problem. (TestOneMKL.zip)
For oneAPI beta10, the build was completed in a few seconds!
I want to solve this problem and use the oneMKL library.
Please tell me the cause and countermeasures.
OS: Windows 10 Pro
Toolkit:
Microsoft Visual Studio 2019 Professional (ver.16.8.3)
Intel oneAPI 2021.1
CPU: Intel Core i7-1165G7 2.80GHz
Accelerator:Intel Iris Xe Graphics
driver ver.: 27.20.100.9030
Best regards.
AbhishekD_Intel
As this thread is more related to MKL, we are moving this thread to Intel MKL Forum.
Warm Regards,
Abhishek
RahulV_intel
The issue is reproducible. Build on VS hangs when "Use MKL" is set to parallel/sequential.
However, it does seem to work when I set the "Use MKL" as No and Additional include directories (Project property pages -> DPC++ ->General) path to MKL_ROOT/include
I have escalated this issue to the concerned team. Thanks for reporting this.
Rahul
Gennady_F_Intel
Yes, we confirmed the issue and it escalated. We will keep this thread informed.
Nikhil_T
@RahulV_intel  @AbhishekD_Intel @Gennady_F_Intel  is there any solution available for this issue ? i am facing the same.
