Install issues
Golden__Bruce
I've followed the MKL 2018 Update 3.  No problem figuring out the configuration for download (Ubuntu 16.04 LTS with gcc, etc).  In the getting started guide it 1st says to check your installation and be sure that "mklvars.sh" and "mklvars.csh" are in (install directory)/bin.  In my case that's /opt/intel/bin, the default from the install script.  In that directory are two files, "compilervars.csh" and "compilervars.sh".  Ok, no big deal.  Intel changed the script names and didn't update the guide.  But when I go to the next step in the guide, "setting the environment variables", and execute the script I get,
$ /opt/intel/bin/compilervars.sh intel64
ERROR: architecture is not defined. Accepted values: ia32, intel64
Syntax:
  source mklvars.sh <arch> [MKL_interface] [mod]
   <arch> must be one of the following
       ia32         : Setup for IA-32 architecture
       intel64      : Setup for Intel(R) 64 architecture
   mod (optional) - set path to Intel(R) MKL F95 modules
   MKL_interface (optional) - Intel(R) MKL programming interface for intel64
                              Not applicable without mod
       lp64         : 4 bytes integer (default)
       ilp64        : 8 bytes integer
If the arguments to the sourced script are ignored (consult docs for
your shell) the alternative way to specify target is environment
variables COMPILERVARS_ARCHITECTURE or MKLVARS_ARCHITECTURE to pass
<arch> to the script, MKLVARS_INTERFACE to pass <MKL_interface> and
MKLVARS_MOD to pass <mod>
/opt/intel/bin/compilervars.sh: 42: [: =: unexpected operator
/opt/intel/bin/compilervars.sh: 50: [: =: unexpected operator
/opt/intel/bin/compilervars.sh: 159: [: =: unexpected operator
/opt/intel/bin/compilervars.sh: 171: [: =: unexpected operator
This seems simple enough and I can't believe it is broken.  What am I doing wrong!?!
Ying_H_Intel
Hi Bruce,
Sorry for  the problem.
It seems the compilervars.sh dees not work as expected.  Could you please try
/opt/intel/mkl/bin/mklvars.sh intel64
We usually use the script under MKLROOT directory.  for example MKLROOT\bin\mklvars.sh.  Could you please let me know the link of getting started guide you are seeing, we may fix the problem there.
Ying
