7300 Discussions
Installation fails --Jave Class Not Found -- on MacBook Pro
don_b_1
I am trying to install the Math Kernel Library under:
Product Subscription Information Download Latest Update Release Posted
Academic Research Performance Libraries from Intel (OS X*)
On my MacBook Pro, when I try to start the install shell, I receive the following message:
./install.sh
In JPanelLicenseOptions
Inside JPanelRegistrationBegin
Calling initComponents
Calling initializePanel
/tmp/intel/se/channel/msg/../msg/20150425124851608,0,Core,0,SmartEngineJavaGUI
Exception in thread "Thread-3" java.lang.NoClassDefFoundError: org/apache/xpath/XPathAPI
    at com.intel.ISSA.GUI.CoreAdapter.MessageReader.getCoreState(MessageReader.java:142)
    at com.intel.ISSA.GUI.CoreAdapter.MessageReader.run(MessageReader.java:45)
Caused by: java.lang.ClassNotFoundException: org.apache.xpath.XPathAPI
    at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
    at java.security.AccessController.doPrivileged(Native Method)
    at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
    at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
    at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
    at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
    ... 2 more
When I click on the Installer from the Finder Window, the Installation Assistant comes up, but the menu window is blank and I cannot continue.
How should I proceed?
How do I submit a Support Ticket?
thank you very much for your help
Victor_C_Intel
Please find all files starting with "intel." in your /tmp and $TMPDIR directories, pack them all into an archive and post here.
Nicholas_N_1
Any update on this?  I received the same error when trying to install on a MacBook Air.
Dan_M_1
Same problem - macbook 2015...
Dan_M_1
Here is the error thrown.. (Run as super user...)
/tmp/intel/se/channel/msg/../msg/20150804033153160,0,Core,0,SmartEngineJavaGUI
Exception in thread "Thread-0" java.lang.NoClassDefFoundError: org/apache/xpath/XPathAPI
    at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
    at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
    at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331)
    at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
    ... 2 more
Dan_M_1
Solution to problem is the following:
mount the volume. Instead of clicking install/running install.sh
find setup folder (hidden). run mkl_p_10.0.5.025.pkg
should work fine. This is a Java error in the classpath to xalan lib...
