7302 Discussions
Installing MKL cluster support for Parallel studio 2017 on a linux Cluster
Marcos_V_1
Hi, we have an install of Fortran Parallel Studio 2017 XE Composer edition (Update 2) on a Centos 6 Linux Cluster, but it happens to be missing the MKL cluster support. So in particular, the mkl/lib/intel64/libmkl_blacs_openmpi_lp64.a library, needed by the cluster_sparse_solver is missing.
We have tried to modify the install from the command window installer provided by intel, but we can't find the cluster support option. Could you please walk us through on adding MKL cluster support on our install? Do we need to uninstall the current parallel studio 2017 first?
Thank you,
Marcos
Zhen_Z_Intel
Hi Marcos,
The Cluster support for MKL is not installed by default, it is under the category of MKL component tree while you install. Please customize your installation option to add MPI interface for MKL functionality.
Fiona
