7287 Discussions
Order of the columns of a sparse matrix (CSR) times a vector
Jeremie_V_
Dear,
I need to multiply a symmetric sparse matrix by a vector and I would like to use the subroutine mkl_dcsrsymv . The upper triangle of the sparse matrix is stored in a CSR format (row major, 3 arrays). However, the elements in the array columns (ja) are not placed in the order in which the associated values occur in the row.
I know that the order is required for MKL Pardiso, but is it also the case for the subroutine mkl_dcsrsymv? Are unordered columns within a row allowed? What are the consequences?
In advance thank you.
Jeremie
Zhen_Z_Intel
Dear customer,
For sparse symmetric matrix calculation, The CSR format could only save up-triangular part to calculate. It is called DSS Symmetric Matrix Storage ,you could refer similar structure format for PARDISO. The csrsymv could also use with DSS symmetric format.
Fiona
Alexander_K_Intel2
You are correct in the fact that pardiso use ordered csr format. By the way spblas routine have not such restriction so you can use not ordered arrays. Also i recommend you to use new spblas API for your operation - in general it perform better
Alex
Jeremie_V_
Dear,
Thank you for you answers.
@Alex, When you mentioned the "new spblas API", do you refer to the Inspector-Executor Sparse Blas routines?
Thank you.
Jeremie
Gennady_F_Intel
yes, exactly
Jeremie_V_
Thank you!
Jeremie
