7300 Discussions
Integrating a C Subfunction for Optimizing R Code
Fio
I have previously asked a question about oneMKL , but I'd like to restate it here. I would appreciate any help.
I would like to perform the compilation of the following C code (which is saved on the path "C:\Users\Desktop\example.c") directly within the R desktop environment.
#include <stdio.h>
#include <mkl.h>
int main() {
    double x[] = {1.0, 2.0, 3.0};
    double y[] = {4.0, 5.0, 6.0};
    double z;
    // Perform vector multiplication and summation using Intel MKL
    z = cblas_ddot(3, x, 1, y, 1);
    printf("Result: %lf\n", z);
    return 0;
I executed the following command in R desktop, but an issue occurred during the process.
> system('icx -o myfunction "C:\\Users\\Desktop\\example.c" /Qmkl /MD')
Intel(R) oneAPI DPC++/C++ Compiler for applications running on Intel(R) 64, Version 2023.1.0 Build 20230320
Copyright (C) 1985-2023 Intel Corporation. All rights reserved.
LINK : fatal error LNK1104: cannot open file 'libiomp5md.lib'
icx: error: linker command failed with exit code 1104 (use -v to see invocation)
[1] 1104
My environment variables are displayed in the image below. 
I've installed the Intel® oneAPI Base Toolkit on a Windows platform.
Than you very much.
IntelSupport
Community Manager
Thanks for posting in Intel communities.
Since this is a duplicate thread of "https://community.intel.com/t5/Intel-oneAPI-Math-Kernel-Library/Integrating-a-C-Subfunction-for-Optimizing-R-Code-Performance-gt/m-p/1526558#M35165 " , we will no longer monitor this thread. We will continue addressing this issue in the other thread.
Thanks & Regards,
Jilani
