7302 Discussions
PARDISO is running in In-Core mode, because iparam(60)=0
Hassan-Ebrahimi
I am trying to make use of OOC PARIDSO but it seems that setting iparam(60)=1 is neglected.
For example with a small matrix I get the following messages:
Statistics:
Parallel Direct Factorization is running on 1 OpenMP
< Linear system Ax = b >
number of equations: 500000
number of non-zeros in A: 50494950
number of non-zeros in A (%): 0.020198
number of right-hand sides: 1
< Factors L and U >
number of columns for each panel: 128
number of independent subgraphs: 0
< Preprocessing with state of the art partitioning metis>
number of supernodes: 10238
size of largest supernode: 242
number of non-zeros in L: 157921408
number of non-zeros in U: 1
number of non-zeros in L+U: 157921409
Reordering Time [s]: 15.5904239001684
=== PARDISO is running in In-Core mode, because iparam(60)=0 ===
Is there other setting needed to see the effect of  setting iparam(60)=1?
The wrapper of pardiso solver is attached.
MKL version: Intel(R) oneAPI Math Kernel Library Version 2022.1-Product Build 20220311 for Intel(R) 64 architecture applications
Thank you in advance.
AryanK_Intel
To make use of OOC(Out Of Core) PARDISO, please assign the value of iparm[59] to 2. If iparm[59] is set to 2, then Intel® MKL PARDISO OOC mode is used.
The default value of iparm[59] is 0.
If iparm[59] is set to 0, then the standard in-core Intel® MKL PARDISO is used.
If iparm[59] is set to 1, then the standard in-core Intel® MKL PARDISO is used.
Please refer to the below link for more details regarding the significance of iparm[59].
https://www.intel.com/content/www/us/en/developer/articles/training/how-to-use-ooc-pardiso.html
Sri Raj Aryan.K
Hassan-Ebrahimi
Hi Sri Raj Aryan.K,
I am using  the Fortran interface of PARDISO.  Am I not supposed to set iparm(60)?
When with iparm(60) =2 the message is still "PARDISO is running in In-Core mode, because iparam(60)=0"  for a matrix of size 1 GB.
For a matrix of size 6.73 GB I get the following error in reordering phase:
************************** mkl_test starts ...
reordering
*** Error in PARDISO ( insufficient_memory) error_num= 1
*** Error in PARDISO memory allocation: MATCHING_REORDERING_DATA, allocation of 1 bytes failed
total memory wanted here: 4906038 kbyte
=== PARDISO: solving a symmetric indefinite system ===
1-based array indexing is turned ON
PARDISO double precision computation is turned ON
METIS algorithm at reorder step is turned ON
Summary: ( reordering phase )
Times:
Time spent in calculations of symmetric matrix portrait (fulladj): 2.843310 s
Time spent in reordering of the initial matrix (reorder) : 0.000000 s
Time spent in symbolic factorization (symbfct) : 0.000000 s
Time spent in allocation of internal data structures (malloc) : 0.007406 s
Time spent in additional calculations : 5.792175 s
Total time spent : 8.642892 s
Statistics:
number of equations: 2000000
number of non-zeros in A: 601954850
number of non-zeros in A (%): 0.015049
< Factors L and U >
number of supernodes: 0
size of largest supernode: 0
number of non-zeros in L: 0
number of non-zeros in U: 0
number of non-zeros in L+U: 0
iparm(15) 0
iparm(16) 0
iparm(18) -1
Reordering completed ...
The following ERROR was detected: -2
1
The Fortran file is attached
Hassan-Ebrahimi
Hi Sri Raj Aryan.K,
The problem is  not solved yet.
Would you please look into the matter?
Hassan
AryanK_Intel
Hi Hassan-Ebrahimi,
Thanks for sharing the Fortran source. We have tried running the shared source code at our end and we could see that the code exiting abruptly with error code -1 which means that the input is inconsistent as per the below Pardiso reference.
https://www.intel.com/content/www/us/en/docs/onemkl/developer-reference-fortran/2023-2/pardiso.html
Regrets for earlier reply, as iparm[60]=2 is the expected value for the OOC mode.
Could you please share with us a sample working reproducer, so that we could work on this accordingly.
Sri Raj Aryan.K
Hassan-Ebrahimi
Hi Sri Raj Aryan.K,
Thanks for your reply.
The crash may be due to the size of the matrix.
Let's make it work for a smaller matrix:
In line 40 of pardiso_sym_iparam60=2.f, we have w=300.  Please reduce it w=30.
With w=30, the factorization completes in less than 30 seconds on my side.
Hassan
AryanK_Intel
Hi Hassan-Ebrahimi,
Thanks for the suggestion. We have tried running the code by changing the value of w=300 to w=30. However, the issue persists for both iparm(60)=0 and iparm(60)=2.
Sri Raj Aryan.K
AryanK_Intel
Hi Hassan-Ebrahimi,
We have not heard back from you. Could you please provide an update on this thread? If possible, please share a sample working reproducer, so that we could work on this accordingly.
Thanks & Regards,
Sri Raj Aryan.K
Hassan-Ebrahimi
Hi Sri Raj Aryan.K
Thanks for your follow-up.
After days of struggling, I found the cause of the original problem.
In my code IPARM(1) = 0.  This seems to reset IPARM(60).
By setting IPARM(1) = 1 and IPARM(60)=2,  PARSDISP runs in OOC mode.
Hassan
AryanK_Intel
Hi Hassan-Ebrahimi,
Thanks for sharing the solution with us.
It’s great to know that the issue has been resolved, in case you run into any other issues please feel free to create a new thread.
Have a Good Day!
Thanks & Regards,
Sri Raj Aryan.K
