7303 Discussions
Intel® MKL 2018 Beta Update 1 is now available
Gennady_F_Intel
Intel® MKL 2018 Beta is now available as part of the Parallel Studio XE 2018 Beta.
Check the Join the Intel® Parallel Studio XE 2018 Beta program post to learn how to join the Beta program, and the provide your feedback.
What's New in Intel® MKL 2018 Beta Update 1:
BLAS:
  • Addressed an early release buffer issue in threaded *GEMV
  • Improved TBB *GEMM performance for small m and n while k is large
DNN:
  • Improved performance on Intel® Xeon Phi™ processor x200 (formerly Knights Landing)
  • Improved convolution performance for Intel(R) Xeon Phi™ processors based on Intel®  Advanced Vector Extensions 512 (Intel®  AVX-512) with support of AVX512_4FMAPS and AVX512_4VNNIW instruction groups
FFT:
  • Improved performance of 3D FFT complex-to-real and real-to-complex scaled and non-scaled problems on Intel® Xeon Phi™ processor 72** (formerly Knights Landing)
  • Improved performance of 2D FFT complex-to-complex problems with scale on Intel® Xeon Phi™ processor 72** (formerly Knights Landing) and on Intel® Xeon processors E3-xxxx V5 (formerly SkyLake)
LAPACK:
  • Completed alignment with Netlib* LAPACK 3.7.0 by integrating all new routines and bug fixes. Notable new features are:
    • Optimized factorization, solve and inverse routines with rook pivoting: ?sytrf_rk/?hetrf_rk, ?sytrs_rk/?hetrs_rk and ?sytri_3/?hetri_3
    • Added LAPACKE interfaces for all new routines including Aasen factorization and solve routines
  • Improved ?gesvd performance for tall-and-skinny matrices.
  • Improved ?gelq/?gemlq  performance for short-and-wide matrices.
Vector Mathematics:
  • Improved performance of vdPowx and vsPowx functions for certain exponent values (0,5,6,7,8,9 )
What's New in Intel® MKL 2018 Beta:
  • DNN:
    • Added initial convolution and inner product optimizations for Intel(R) Xeon Phi(TM) processors based on Intel(R) Advanced Vector Extensions 512 (Intel(R) AVX-512) with support of AVX512_4FMAPS and AVX512_4VNNIW instruction groups.
    • Average pooling has an option to include padding into mean values computation
  • BLAS Features:
    • Introduced optimized integer matrix-matrix multiplication routines (GEMM_S16S16S16 and GEMM_S16S16S32) to work with quantized matrices for all architectures.
    • Introduced ?TRSM_BATCH to complement the batched BLAS for all architectures
  • BLAS Optimizations:
    • Optimized SGEMM, GEMM_S16S16S16 and GEMM_S16S16S32 for Intel(R) Xeon Phi(TM) processors based on Intel(R) Advanced Vector Extensions 512 (Intel(R) AVX-512) with support of AVX512_4FMAPS and AVX512_4VNNIW instruction groups
    • Improved ?GEMM_BATCH performance for all architectures
    • Improved single and multi-threaded {D,S}SYMV performance for Intel® Advanced Vector Extensions 512 (Intel® AVX-512) and the Intel® Xeon Phi™ processor x200
  • Sparse BLAS:
    • Improved performance of CSRMV/BSRMV functionality for Intel® AVX-512 instruction set in Inspector-Executor mode
  • LAPACK:
    • Introduced factorization and solve routines based on Aasen's algorithm: ?sytrf_aa/?hetrf_aa, ?sytrs_aa/?hetrs_aa
  • Vector Mathematics:
    • Added 24 new functions: v?Fmod, v?Remainder, v?Powr, v?Exp2; v?Exp10; v?Log2; v?Logb; v?Cospi; v?Sinpi; v?Tanpi; v?Acospi; v?Asinpi; v?Atanpi; v?Atan2pi; v?Cosd; v?Sind; v?Tand; v?CopySign; v?NextAfter; v?Fdim; v?Fmax; v?Fmin; v?MaxMag; v?MinMag
  • Library Engineering:
    • Introduced support for Intel(R) Xeon Phi(TM) processors based on Intel(R) Advanced Vector Extensions 512 (Intel(R) AVX-512) with support of AVX512_4FMAPS and AVX512_4VNNIW instruction groups.
Optimizations are not dispatched unless explicitly enabled with mkl_enable_instructions function call or MKL_ENABLE_INSTRUCTIONS environment variable.
  • Documentation:
  • Hardware Support for Intel® Xeon Phi™ Coprocessors (code name Knights Corner) is removed. Customers are recommended to stay on MKL 2017 given they continue to use and develop for Intel® Xeon Phi™  Coprocessors (aka Knight Corner)
