Intel MKL CSR format documentation
mostafanouh
In the latest documentation for CSR format here
https://software.intel.com/content/www/us/en/develop/documentation/mkl-developer-reference-c/top/appendix-a-linear-solvers-basics/sparse-matrix-storage-formats/sparse-blas-csr-matrix-storage-format.html
I found that definition for pointerE array
"pointerE
An integer array that contains row indices, such that pointerE-indexing is the index of the element
 in the values array that is last non-zero element in a row j of A."
I failed to apply this definition to the examples in the same link so I think this definition is wrong or I'm missing something trivial.
Can any one clarify that please.
MariaZh
You're correct, there is a mistake in CSR format description. Thanks for catching the issue!
The pointerE should be something like "..., such that pointerE - 1 - indexing is the index of the element in the values array that is last non-zero element in a row j of A".
You can also refer to BSR storage format description and example.
Maria
MariaZh
Maria
