Intel MKL ERROR: Parameter 4 was incorrect on entry to DSTEIN2
4f0drlp7eyj3
   Some users are seeing the following error messages when running VASP, built against Intel 2018.0.3.
Intel MKL ERROR: Parameter 4 was incorrect on entry to DSTEIN2.
Intel MKL ERROR: Parameter 6 was incorrect on entry to DSTEIN2
The behavior was noticed as the rank count increased, and https://www.mail-archive.com/wien@zeus.theochem.tuwien.ac.at/msg17897.html also suggests that this behavior might be expected as rank count exceeds some level.
Is this expected behavior from MKL, and if so, what is the guidance on MPI rank count vs. matrix property (size?)?
Gennady_F_Intel
Yes, we know this. This problem has been fixed since MKL 2019.0. Could you please try to check this version or the latest 2019.1 one and let us know the results.
4f0drlp7eyj3
OK, thanks Gennady. I will work to get 2019.1 up and update when I can.
Gennady_F_Intel
just in the case -- here is the link to the MKL Bug Fix list : https://software.intel.com/en-us/articles/intel-math-kernel-library-2019-bug-fixes#  see MKLD-3725 Fixed error: Parameter 6 was incorrect on entry to DSTEIN routine
4f0drlp7eyj3
Thanks Gennady, MKL 2019.1 appears to have fixed the issue.
Gennady_F_Intel
welcome :)
I__A
I can't change the MKL version to the 2019 one. So if I were to keep working with an old MKL version, could you please tell me what causes this error with VASP? Thanks.
