7302 Discussions
Intel MKL Error Parameter 4 was incorrect on entry to DGELSD.
Nothing__S
I get this error when training a neural net using using Theano and Lasagne.
In particular, I get this error when taking the square or square root of a variable e.g., theano.tensor.sqr(input)
In case it helps:
I've installed python packages: mkl 2018.0.3, mkl-service 1.1.2, mkl_fft 1.0.4, mkl_random 1.0.1
Please advise.
mecej4
Please ask in the Intel Distribution for Python Forum, https://software.intel.com/en-us/forums/intel-distribution-for-python .
If you can record and report on the arguments passed to DGELSD, you can post the details and ask for help here.
Ying_H_Intel
How about change the input a little manually and see if  any change.
Here is some information for your reference
gelsd
Computes the minimum-norm solution to a linear least squares problem using the singular value decomposition of A and a divide and conquer method.
https://software.intel.com/en-us/mkl-developer-reference-fortran-gelsd
call dgelsd(m, n, nrhs, a, lda, b, ldb, s, rcond, rank, work, lwork, iwork, info)
Return Values
This function returns a value info.
If info=0, the execution is successful.
If info = -i, the i-th parameter had an illegal value.
If info = i, then the algorithm for computing the SVD failed to converge; i indicates the number of off-diagonal elements of an intermediate bidiagonal form that did not converge to zero.
if possible, please provide  the input  of the function of gelsd and check the error.
or please submit the issue by  Theano and Lasagne .
Ying
