7282 Discussions
Intel MKL FFT for forward and backward Fourier transform of 2D data
Londhe__Ashutosh
I am trying to do forward and backward Fourier transform using the FFT routines available in Intel MKL. I have taken help of manual and also website examples to do this but i am getting a segmentation fault. Please help me to resolve it.
I am taking real valued as input to FFT forward and want output in Complex form.
Following is my code which i have implemented so far
#include <iostream>
#include "mkl_dfti.h"
typedef struct {
    float re;
    float im;
} mkl_float_complex;
using namespace std;
int main(int argc, char **argv)
//Read binary file in array xr_in dimension 2001 X 1911
n2=2001 n1=1911
    mkl_float_complex **xc_out;
    DFTI_DESCRIPTOR_HANDLE desc_handle_for, desc_handle_back;
    MKL_LONG status;
    MKL_LONG lengths[2];
    lengths[0] = n2;      lengths[1] = n1;
    xc_out = (mkl_float_complex**) malloc(sizeof(mkl_float_complex*)*n2);
    for(i2 = 0; i2 < n2; i2++)
        xc_out[i2] = (mkl_float_complex*) malloc(sizeof(mkl_float_complex)*n1);
    status = DftiCreateDescriptor(&desc_handle_for, DFTI_SINGLE, DFTI_REAL, 2, lengths);
    status = DftiSetValue(desc_handle_for, DFTI_CONJUGATE_EVEN_STORAGE, DFTI_COMPLEX_COMPLEX);
    status = DftiSetValue(desc_handle_for, DFTI_PACKED_FORMAT,          DFTI_CCE_FORMAT);
    status = DftiSetValue(desc_handle_for, DFTI_PLACEMENT,              DFTI_NOT_INPLACE);
    status = DftiCommitDescriptor(desc_handle_for);
    status = DftiComputeForward(desc_handle_for, xr_in, xc_out);
    status = DftiFreeDescriptor(&desc_handle_for);
     //Writing real part only to file
    //Open file
        for(i1 = 0; i1 < n1; i1++)
            fwrite(&(xc_out[i2][i1].re), sizeof(float), 1, fp);
   //Close file
}//End of main
Zhen_Z_Intel
Hi Ashutosh,
Please define input/output matrix as two dimentional array to replace using pointer. You must insure data is saved in continuous memory space.
Like:
mkl_float_complex xr_in[2001][1191];
    xr_in.re=...;
    xr_in.im=...;
Zhen_Z_Intel
Hi Ashutosh,
Like:
    xr_in.re=...;
    xr_in.im=...;
Londhe__Ashutosh
Dear Fiona Z,
The solution you provided worked.
Now no error, but i have written the real and imag part to separate file which shows only half of the portion and other half is zero in n1 dimension. Do i need to increase the number of transform. Or do i have to set any other value also apart from which are specified in code snippet.
Zhen_Z_Intel
Hi Ashutosh,
You created descriptor that Forward domain of the transform is real not complex. image part would not be calculated. That's the reason you get all values of im with zero. Please refer developer reference: https://software.intel.com/en-us/node/521976
