7303 Discussions
Intel MKL results differ depending on the underlying hardware architecture
anonuser123
I think this is a well known problem that when using MKL_CBWR=AUTO, the results may differ across different hardware architecture due to the floating point arithmetic that occurs.
My question is in such cases, when the results are system-dependent, how do you evaluate which one of the results is the closer to the true theoretical result?
Which MKL_CBWR settings is most appropriate for accuracy?
Mahan
As there was no response, I assume that the above link might have been able to resolve the issue.
I am closing this thread for now.
Please open a separate thread if you face any further issues.
Mahan
Please let me know if the following link helps. It shows how one can obtain numerical reproducibility.
https://www.intel.com/content/www/us/en/docs/onemkl/developer-guide-windows/2024-1/get-started-with-conditional-num-reproducibility.html
Mahan
Please let me know if there is any update.
Mahan
