7302 Discussions
d_Helmholtz_3D_c.c crashes with Unhandled exception (KernelBase.dll). Module not found.
AhmadOneAPI
I want to build and run the attached code using Visual Studio 2022 Community that uses Intel MKL 2024 and C++20 under Windows 10 64bit.
The project is very simple and is trying to run the following example provided by Intel OneAPI MKL 2024
C:\Program Files (x86)\Intel\oneAPI\2024.1\share\doc\mkl\examples\examples_core_c\c\pdepoisson\source\d_Helmholtz_3D_c.c
Include and library folders are:
C:\Program Files (x86)\Intel\oneAPI\mkl\2024.1\lib
C:\Program Files (x86)\Intel\oneAPI\mkl\2024.1\include
Dependencies are:
mkl_core.lib
mkl_rt.lib
DLLs copied to the folder containing the executable of the project are:
mkl_avx512.2.dll
mkl_core.2.dll
mkl_def.2.dll
mkl_intel_thread.2.dll
mkl_rt.2.dll
mkl_sequential.2.dll
Issue:
My project is built successfully for x64 Debug but when execution reaches the following line:
d_init_Helmholtz_3D(&ax, &bx, &ay, &by, &az, &bz, &nx, &ny, &nz, BCtype, &q, ipar, dpar, &stat);
I get the following exception and d_init_Helmholtz_3D never returns successfully:
Unhandled exception at 0x00007FFFB8D6AB89 (KernelBase.dll) in IntelMKLIssue.exe: 0xC06D007E: Module not found (parameters: 0x000000AA1A4FE6F0).
The call stack is as follows
KernelBase.dll!00007fffb8d6ab89() Unknown
mkl_intel_thread.2.dll!00007ffec10adb5e() Unknown
mkl_intel_thread.2.dll!00007ffec10b2e55() Unknown
mkl_intel_thread.2.dll!00007ffebf1e6bdc() Unknown
mkl_intel_thread.2.dll!00007ffebfd58b62() Unknown
mkl_avx512.2.dll!00007ffea8d1c08b() Unknown
mkl_core.2.dll!00007ffeaacd12ff() Unknown
mkl_rt.2.dll!00007ffec29e6649() Unknown
> IntelMKLIssue.exe!main() Line 215 C++
The line 215 is the following if statement.
if (stat != 0) {
   error = 1;
   goto end;
I don't think I am missing any lib s or DLLs. I intentionally made my project to link against all the lib files in C:\Program Files (x86)\Intel\oneAPI\mkl\2024.1\lib and also copied all the DLLs in C:\Program Files (x86)\Intel\oneAPI\mkl\2024.1\bin into my executable folder, still I get the same exception message. Although I don't need to do all the libs and DLLs, I did it anyway to rule out any potential missing files.
How can I know what lib and DLL files a specific MKL function needs? I could not find this info on MKL PDF documentation.
Ruqiu_C_Intel
Looks it works well in my side for your code.
 Example of use of  Intel oneMKL Poisson Library
 This example gives the solution of 3D Helmholtz problem
 with the equation -u_xx-u_yy-u_zz+u=f(x,y,z), 0<x<1, 0<y<1, 0<z<1,
 f(x,y,z)=(12*pi*pi+1)*sin(2*pi*x)*sin(2*pi*y)*sin(2*pi*z)+1,
 and with the following boundary conditions:
  u(0,y,z)=u(1,y,z)=1 (Dirichlet boundary conditions),
 -u_y(x,0,z)=-2.0*pi*sin(2*pi*x)*sin(2*pi*z) (Neumann boundary condition),
  u_y(x,1,z)= 2.0*pi*sin(2*pi*x)*sin(2*pi*z) (Neumann boundary condition),
 -u_z(x,y,0)=-2.0*pi*sin(2*pi*x)*sin(2*pi*y) (Neumann boundary condition),
  u_z(x,y,1)= 2.0*pi*sin(2*pi*x)*sin(2*pi*y) (Neumann boundary condition).
 In general, the error should be of order O(1.0/nx^2+1.0/ny^2+1.0/nz^2)
 For this example, the value of nx=ny=nz is 4
 The approximation error should be of order 5.0e-01, if everything is OK
                      DOUBLE PRECISION COMPUTATIONS
The number of mesh intervals in x-direction is nx=4
The number of mesh intervals in y-direction is ny=4
The number of mesh intervals in z-direction is nz=4
In the mesh point (0.25,0.00,0.00) the error between the computed and the true solution is equal to -3.896e-01
In the mesh point (0.25,0.00,0.25) the error between the computed and the true solution is equal to -1.978e-01
In the mesh point (0.25,0.00,0.50) the error between the computed and the true solution is equal to -2.220e-16
In the mesh point (0.25,0.00,0.75) the error between the computed and the true solution is equal to  1.978e-01
In the mesh point (0.25,0.00,1.00) the error between the computed and the true solution is equal to  3.896e-01
In the mesh point (0.25,0.25,0.00) the error between the computed and the true solution is equal to -1.978e-01
In the mesh point (0.25,0.25,0.25) the error between the computed and the true solution is equal to  1.660e-01
In the mesh point (0.25,0.25,0.50) the error between the computed and the true solution is equal to -2.220e-16
In the mesh point (0.25,0.25,0.75) the error between the computed and the true solution is equal to -1.660e-01
In the mesh point (0.25,0.25,1.00) the error between the computed and the true solution is equal to  1.978e-01
In the mesh point (0.25,0.50,0.00) the error between the computed and the true solution is equal to -4.441e-16
In the mesh point (0.25,0.50,0.25) the error between the computed and the true solution is equal to -4.441e-16
In the mesh point (0.25,0.50,0.50) the error between the computed and the true solution is equal to -2.220e-16
In the mesh point (0.25,0.50,0.75) the error between the computed and the true solution is equal to -3.331e-16
In the mesh point (0.25,0.50,1.00) the error between the computed and the true solution is equal to -3.331e-16
In the mesh point (0.25,0.75,0.00) the error between the computed and the true solution is equal to  1.978e-01
In the mesh point (0.25,0.75,0.25) the error between the computed and the true solution is equal to -1.660e-01
In the mesh point (0.25,0.75,0.50) the error between the computed and the true solution is equal to -3.331e-16
In the mesh point (0.25,0.75,0.75) the error between the computed and the true solution is equal to  1.660e-01
In the mesh point (0.25,0.75,1.00) the error between the computed and the true solution is equal to -1.978e-01
In the mesh point (0.25,1.00,0.00) the error between the computed and the true solution is equal to  3.896e-01
In the mesh point (0.25,1.00,0.25) the error between the computed and the true solution is equal to  1.978e-01
In the mesh point (0.25,1.00,0.50) the error between the computed and the true solution is equal to -2.220e-16
In the mesh point (0.25,1.00,0.75) the error between the computed and the true solution is equal to -1.978e-01
In the mesh point (0.25,1.00,1.00) the error between the computed and the true solution is equal to -3.896e-01
 Double precision 3D Helmholtz example has successfully PASSED
 through all steps of computation!
C:\Users\rcao8\source\repos\mklTest\x64\Debug\mklTest.exe (process 16328) exited with code -1.
To automatically close the console when debugging stops, enable Tools->Options->Debugging->Automatically close the console when debugging stops.
Press any key to close this window . . .
BRs,
Ruqiu
Ruqiu_C_Intel
I am closing this thread for now.
Please open a separate thread if you face any further issues.
