7299 Discussions
Unhandled exception at 0x68945314 (KernelBase.dll). Module not found.
AhmadOneAPI
I have the same problem posted on Intel.
First Machine:
I am using Visual Studio 2022 Community and I am using s_init_Helmholtz_3D from MKL library.
My VS Solution is built successfully using the MKL lib and runs successfully with MKL DLLs. My VS Solution has a folder named External that contains all the dependencies including, lib, DLL, and header files in:
External/bin
External/include
External/lib
External/debug/bin
External/debug/lib
My Solution uses the following lib files:
Iphlpapi.lib
ws2_32.lib
wsock32.lib
netapi32.lib
mkl_core.lib
mkl_rt.lib
mkl_sequential.lib
mkl_sycl.lib
mkl_tbb_thread.lib
As a Post-Event, my VS solution copies all the DLLs inside External/debug/bin and External/bin to $(SolutionDir)/x64/Debug and $(SolutionDir)/x64/Release, respectively.
Second Machine (Similar to the First Machine): The Issue:
I can successfully build the same Solution using Visual Studio 2022 Community on a different Windows machine but when I run it I get the following error.
On the second machine, I have made sure OneAPI install folder is not in the system Path. My VS Solution is self-contained and does not use any dependencies other than the one in the External folder (I am not using vcpkg VS integration) and I expect the executable to work.
Even as another test, I copied the build folder $(SolutionDir)/x64/Debug and $(SolutionDir)/x64/Release from the first machine to the second machine and ran my executable but the problem still exits. These build folders have all the dependent MKL DLLs in them. This test is trying to tell me something about my crashing executable on the second machine but I can't figure it out.
I need help on what I could be missing that is causing this. I feel like my VS solution is not using the correct lib file and/or DLLs. The confusing part for me is that, then why is it working on the first machine?
Ruqiu_C_Intel
We recommend you to use neMKL link advisor below for oneMKL compile and linkage options.
https://www.intel.com/content/www/us/en/developer/tools/oneapi/onemkl-link-line-advisor.html
If you still have problem, please provide out a simple reproducer.
BRs,
Ruqiu
Ruqiu_C_Intel
As there was no response, I assume that the above link might have been able to resolve the issue.
I am closing this thread for now.
Please open a separate thread if you face any further issues.
