7298 Discussions
Intel® Math Kernel Library 11.2 Update 1 is now available
Sridevi_A_Intel
Intel® Math Kernel Library (Intel® MKL) is a highly optimized, extensively threaded, and thread-safe library of mathematical functions for engineering, scientific, and financial applications that require maximum performance. Intel MKL 11.2 Update 1 packages are now ready for download. Intel MKL is available as part of the Intel® Parallel Studio XE 2015 . Please visit the Intel® Software Evaluation Center to evaluate this product.
Intel® MKL 11.2 Update 1 Bug fixes
What's New in Intel® MKL 11.2 Update 1 :
  • Introduced support for Intel® Advanced Vector Extensions 512 (Intel® AVX-512) on Intel® Xeon® processors for Windows* and Linux* versions of Intel MKL. This is in addition to the current support for Intel® AVX-512 instructions for Intel® Many Integrated Core Architecture (Intel® MIC Architecture)
  • Introduced support for LAPACK version 3.5
  • Added support for Schur complement including getting explicit Schur complement matrix and solving the system through Schur complement
  • Deprecations: Intel® MKL Cluster Support for IA 32 is now Deprecated and support will be removed in the next major release of Intel MKL
Check Out the Release Notes
LCDM_H_
I've recently installed Intel Parallel Studio XE 2015, here is the output:
icc --version
icc (ICC) 15.0.0 20140723
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
how do I check what version of MKL?
How do I update to MKL 11.2 Update 1?
Here is the error output:
.../mkl/lib/intel64/libmkl_intel_thread.so: undefined reference to `__isoc99_sscanf'
Tam
mecej4
Since MKL is not a required part of ICC, you have to compile and link a small program to MKL and run it to get the version. See https://software.intel.com/en-us/node/471128 .
Regarding the undefined reference: please provide more details including, if possible, a small program that shows the linker error when a build is attempted.
Ying_H_Intel
Hi LCDM and Mecej4,
Thanks for the reports.  Right, the issue was in MKL 11.2.0 and was fixed in MKL 11.2.1.  Please see
https://software.intel.com/en-us/articles/intel-mkl-112-bug-fixes
DPD200547167 Fixed the problem of "ibmkl_core.so: undefined reference to `__isoc99_fscanf'" with MKL 11.2 on RHEL5
 You can check the MKL versions by check the MKL header file.  for example,  C:\Program Files (x86)\Intel\Composer XE 2013 SP1\mkl\include\mkl.h
#define __INTEL_MKL_BUILD_DATE 20140416
#define __INTEL_MKL__ 11
#define __INTEL_MKL_MINOR__ 1
#define __INTEL_MKL_UPDATE__ 3
or call function :
 mkl_get_version
A C function that returns the Intel MKL version.
Syntax
void mkl_get_version( MKLVersion* pVersion);
Include Files
• C: mkl.h
or check the webpage: https://software.intel.com/en-us/articles/which-version-of-the-intel-ipp-intel-mkl-and-intel-tbb-libraries-are-included-in-the-intel
Ying
