Is there a parallel implementation of mkl_sparse_d_trsv()?
janalik__radim
I'm using function mkl_sparse_d_trsv(). No matter how many threads I use (environment variable MKL_NUM_THREADS), the performance is always the same. So it seems to me that this function has no parallel implementation.
Can somebody confirm my assumption, please? Or am I wrong?
Thank you.
Alexander_K_Intel2
Hi Radim,
The function mkl_sparse_d_trsv is threaded but it's scalling can significantly depend on matrix structure. Also, to calculate internal data for parallel implementation one need to call optimize() and mkl_sparse_set_sv_hint routines before
Alex
Alexander_K_Intel2
Hi Radim,
Alex
janalik__radim
Thank you.
