7287 Discussions
Is there a way to link only mkl lapack somehow? but not all mkl?
utab
I was wondering if there is a way to only link mkl lapack? If yes, which files should I use in linking?
Best,
Umut
barragan_villanueva_
Valued Contributor I
In case if you want to get small execatableplease usestatic linking with MKL libraries.
If you need some small dynamic library with limited set of MKL functions (e.g. subset of LAPACK) please use MKL custom builder.
Otherwise, please explain your reasons tolink with mkl lapack
what kind of library: static or dynamic to deployapplication or create some plug-in
it is about size of your application or plug-in
TimP
If you want to use lapack without using MKL BLAS, you should not be using MKL lapack. There isn't so much MKL specific optimization in lapack anyway; it's perfectly feasible to use open source.
Maybe that's not the question you meant to ask.
