JTIME and HELP
JohnNichols
Honored Contributor I
Steve:
I wanted to use the JTIME routine in the IFPORT Library.
Your help files has it as a function, but it now appears to be a called subroutine.
Your
results = Jtime()
returns an error on compile
call Jtime(results)
works fine.
Just letting you know.
The help viewer when trying to call up the Fortran Help Files crashes a lot. I have VS upto date and latest Fortran.
When Help Viewer works it is great, but it is a bit weird with the crashes.
JMN
TimP
The same subject was discussed at length in this duplicate thread
