7276 Discussions
Is there any way to utilize BLAS with symmetry for high rank tensor/array in Fortran MKL?
AlphaF20
I came cross a type of tensor contraction with symmetry in individual tensor(s) in Fortran.  I heard it is related to MKL. Hence, I posted this question here.
The question is, is there a way to utilize such symmetries in BLAS?
For instance, for a tensor contraction
A[a,b] * B[b,c,d] = C[a,c,d]
where the Einstein summation rule was assumed, repeated index, b, stands for summation. i.e., \sum_b in the above equation. Tensor/array A,B,C are all real. The tensor/array b has a symmetry
B[b,c,d] = B[b,d,c]
which leads to
C[a,c,d] = C[a,d,c]
In BLAS, there are some subroutines about symmetric matrix, but not higher rank tensor/array as far as I know. Is there any way to utilize the above symmetries in DGEMM or any other subroutines?
I heard to first do loops over indices c and d, then do DGEMM with array with fewer indices. If I define new arrays
B_small(:) = B(:,c,d), C_small(:) = C(:,c,d)
that would take a bit time (I think I tested the wall time at some stage). Hence, I would like to know any efficient solution. My attempt code is following
Program blas_symm_tensor
  Use, Intrinsic :: iso_fortran_env, Only :  wp => real64, li => int64
  Implicit None
  Real( wp ), Dimension( :, :    ), Allocatable :: a
  Real( wp ), Dimension( :, :, : ), Allocatable :: b
  Real( wp ), Dimension( :, :, : ), Allocatable :: c1, c2, c3, c4, c5
  Integer :: na, nb, nc, nd, ne
  Integer :: la, lb, lc, ld
  Integer( li ) :: start, finish, rate, numthreads
  Write( *, * ) 'na, nb, nc, nd ?'
  Read( *, * ) na, nb, nc, nd
  ne = nc * nd
  Allocate( a ( 1:na, 1:nb ) )
  Allocate( b ( 1:nb, 1:nc, 1:nd ) )
  Allocate( c1( 1:na, 1:nc, 1:nd ) )
  Allocate( c2( 1:na, 1:nc, 1:nd ) )
  Allocate( c3( 1:na, 1:nc, 1:nd ) )
  Allocate( c4( 1:na, 1:nc, 1:nd ) )
  Allocate( c5( 1:na, 1:nc, 1:nd ) )
  ! Set up some data
  Call Random_number( a )
  Call Random_number( b )
  ! symmetrize tensor b
  do la = 1, na
    do lc = 1, nc
      do ld = lc+1, nd
         b(la,lc,ld) = b(la,ld,lc)
      enddo
    enddo
  enddo
  Call System_clock( start, rate )
  c1 = 0.0_wp
  do ld = 1, nd
    do lc = 1, nc
      do lb = 1, nb
        do la = 1, na
          c1(la,lc,ld) = c1(la,lc,ld)  + a(la,lb) * b(lb, lc, ld)
        enddo
      enddo
    enddo
  enddo
  Call System_clock( finish, rate )
  Write( *, * ) 'Time for loop', Real( finish - start, wp ) / rate
  c2 = 0.0_wp
  do ld = 1, nd
    do lc = 1, ld
      do lb = 1, nb
        do la = 1, na
          c2(la,lc,ld) = c2(la,lc,ld)  + a(la,lb) * b(lb, lc, ld)
        enddo
      enddo
    enddo
  enddo
  do ld = 1, nd
    do lc = ld+1, nc
      do la = 1, na
        c2(la,lc,ld) = c2(la,ld,lc)
      end do
    enddo
  enddo
  Write( *, * ) 'Time for symmetric loop', Real( finish - start, wp ) / rate
  c3 = 0.0_wp
  do ld = 1, nd
    do lc = 1, ld
       Call dgemm( 'N', 'N', na, 1, nb, 1.0_wp, a , Size( a , Dim = 1 ), &
                                            b(:,lc,ld) , Size( b , Dim = 1 ), &
                                            0.0_wp, c3, Size( c3, Dim = 1 ) )
    enddo
  enddo
  do ld = 1, nd
    do lc = ld+1, nc
      do la = 1, na
        c3(la,lc,ld) = c3(la,ld,lc)
      end do
    enddo
  enddo
  Write( *, * ) 'Time for symmetric dgemm', Real( finish - start, wp ) / rate
  ! Direct
  Call dgemm( 'N', 'N', na, ne, nb, 1.0_wp, a , Size( a , Dim = 1 ), &
                                            b , Size( b , Dim = 1 ), &
                                            0.0_wp, c4, Size( c4, Dim = 1 ) )
  Write( *, * ) 'Time for straight dgemm', Real( finish - start, wp ) / rate
  c5 = 0.0_wp
  do ld = 1, nd
    do lc = 1, ld
       Call dgemv( 'N', na,  nb, 1.0_wp,  a, na, b(1,lc,ld), 1, 0.0_wp,  c5, 1 )
    enddo
  enddo
  do ld = 1, nd
    do lc = ld+1, nc
      do la = 1, na
        c5(la,lc,ld) = c5(la,ld,lc)
      end do
    enddo
  enddo
  Write( *, * ) 'Time for symmetric dgemv', Real( finish - start, wp ) / rate
  do la = 1, na
    do lc = 1, nc
      do ld = 1, nd
         if ( dabs(c1(la,lc,ld) - c2(la,lc,ld))  > 1.e-6 ) then
           write (*,*) '!!! c2', la,lc,ld, c1(la,lc,ld) - c2(la,lc,ld)
         endif
         if ( dabs(c1(la,lc,ld) - c3(la,lc,ld))  > 1.e-6 ) then
           write (*,*) '!!! c3', la,lc,ld, c1(la,lc,ld) - c3(la,lc,ld)
         endif
         if ( dabs(c1(la,lc,ld) - c4(la,lc,ld))  > 1.e-6 ) then
           write (*,*) '!!! c4', la,lc,ld, c1(la,lc,ld) - c4(la,lc,ld)
         endif
         if ( dabs(c1(la,lc,ld) - c5(la,lc,ld))  > 1.e-6 ) then
           write (*,*) '!!! c5', la,lc,ld, c1(la,lc,ld) - c5(la,lc,ld)
         endif
      enddo
    enddo
  enddo
End Program blas_symm_tensor
I got different number in resulting array c3 (DGEMM) and c5 (DGEMV)
Thank you very much!
Peter_C_Intel
Another option, if you only need e.g. the "upper triangle" of C to be stored, is to do a loop in the d dimension around DGEMM:
for d = 1...ld
       C(:, 1:d, d) <- A * B(:, 1:d, d)
The inner matrix multiplications can be performed with DGEMM.
RahulV_intel
We are working on your query internally and will get back to you.
Rahul
Peter_C_Intel
Hi @AlphaF20 , thanks for your question!
As you mentioned, you can use DGEMM to perform this contraction, and in fact you can do it with a single DGEMM call if you'd like. Going back to your original operation:
C[a,c,d] <- A[a,b] * B[b,c,d]
notice you can flatten the last two indices (c,d) into a single linear index f without rearranging the data:
C'[a,f] <- A[a,b] * B'[b,f]
Here I've reinterpreted C, B as matrices C', B' of size la x (lc*ld) and lb x (lc*ld) respectively. The single index f replaces the two indices c, d (f = c + d *lc), and ranges from 1...lc*ld. This is a plain matrix multiply, so you can call MKL DGEMM.
So far we haven't taken any advantage of the symmetry of B. If it works for the rest of the application, you could only store the unique elements of B' by keeping only the unique columns, say where c <= d. In this way, f becomes a linear index into the "upper triangles" of B, ranging from 1...(lc*(lc + 1)/2).
AlphaF20
Hi @Peter_C_Intel ,
  Thank you so much for your answer!
  About >you could only store the unique elements of B' by keeping only the unique columns, say where c <= d.
  May I know how to realize it?
  I can define new arrays with smaller dimensions, e.g., B''(:,:), and using the second dimension to store the upper triangle indices. My experience from other cases is that, introducing new arrays take some time. It may compensate for the advantage of utilizing the symmetry. Hence, I would like to know if there is any method can do DGEMM without using any additional arrays.
 Maybe I should try to test more cases with new arrays such as B''(:,:) and comparing the timing.
Peter_C_Intel
Hi @AlphaF20 -- At the moment I can't think of a clever way to avoid copying data if you need the full 3D tensor in other parts of your code. How large are la/lb/lc/ld typically for your use case?
AlphaF20
Hi @Peter_C_Intel ,
  Thank you so much for your prompt reply.  My la is about 20~30, lb~ld about 30~60. In some cases, I need to deal with higher dimensional arrays and the calculation needs to be done multiple times. The accumulate wall time can be high.
Peter_C_Intel
for d = 1...ld
AlphaF20
Hi @Peter_C_Intel ,
  Thank you so much for your wonderful suggestion! I appreciate it!
  I tried the following code to implement your idea
  Real( wp ), Dimension( :, :, : ), Allocatable :: c6
  Allocate( c6( 1:na, 1:nc, 1:nd ) )
  c6 = 0.0_wp
  do ld = 1, nd
                                            b(:,1:ld,ld) , Size( b , Dim = 1 ), &
                                            0.0_wp, c6, Size( c6, Dim = 1 ) )
  enddo
  do ld = 1, nd
    do lc = ld+1, nc
      do la = 1, na
        c6(la,lc,ld) = c6(la,ld,lc)
      end do
    enddo
  enddo
    do la = 1, na
      do lc = 1, nc
        do ld = 1, nd
         if ( dabs(c1(la,lc,ld) - c6(la,lc,ld))  > 1.e-6 ) then
           write (*,*) '!!! c6 symmetric dgemm-2', la,lc,ld, c1(la,lc,ld) - c5(la,lc,ld)
         endif
      enddo
    enddo
  enddo
I got different numbers than the nested loop value c1 (in the code of the first post). Perhaps I made some mistake in using DGEMM
  How to do DGEMM correctly here? I am sorry for bothering you so many times.
Peter_C_Intel
Hi @AlphaF20 -- your code looks mostly good; remember to also index into C:
dgemm(..., c6(:,1:ld,ld), ...)
AlphaF20
Hi @Peter_C_Intel ,
Thank you so much!
I revised to
  do ld = 1, nd
                                            0.0_wp,  c6(:,1:ld,ld), Size( c6, Dim = 1 ) )
  enddo
still got different value than c1 from nested loops.   I used ifort (IFORT) 19.0.3.199 20190206 and compile the f90 file using ifort -mkl.
Peter_C_Intel
@AlphaF20 Which entries in c6 are incorrect? (all of them?)
AlphaF20
Hi @Peter_C_Intel,
 Thank you once again for your reply. I appreciate your help!
  Many entries, not exactly upper triangle. By the printing code
  do la = 1, na
    do lc = 1, nc
      do ld = 1, nd
           write (*,*) '!!! c6 symmetric dgemm-2', la,lc,ld, c1(la,lc,ld), c6(la,lc,ld)
         endif
      enddo
    enddo
  enddo
led to (na=nb=nc=nd=5)
!!! c6 symmetric dgemm-2           1           2           2
   1.31348887015712       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           1           2           3
  0.837588080628633       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           1           2           4
  0.753232695495532       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           1           2           5
  0.478117026507440       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           1           3           2
 !!! c6 symmetric dgemm-2           1           3           3
   1.60546094997582       0.000000000000000E+000
I don't know where I made the mistake with DGEMM
If you need any additional information, please let me know. I try to be as clear as I can.
Peter_C_Intel
That's strange that e.g. the (1,2,4) entry is incorrect (zero), while the (1,4,2) entry is correct, since the (1,4,2) entry was copied from the (1,2,4) entry.
AlphaF20
Oops, I did not paste all inconsistent entries
 !!! c6 symmetric dgemm-2           1           3           4
  0.635405154591089       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           1           3           5
  0.936981465066013       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           1           4           2
 !!! c6 symmetric dgemm-2           1           4           3
 !!! c6 symmetric dgemm-2           1           4           4
  0.951465241952073       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           1           4           5
   1.35589302240768       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           1           5           2
 !!! c6 symmetric dgemm-2           1           5           3
 !!! c6 symmetric dgemm-2           1           5           4
 !!! c6 symmetric dgemm-2           1           5           5
  0.947407510599024       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           2           2           2
  0.982740142784391       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           2           2           3
  0.454261565081234       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           2           2           4
  0.379019697626723       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           2           2           5
  0.463878131907890       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           2           3           2
 !!! c6 symmetric dgemm-2           2           3           3
   1.38584009273324       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           2           3           4
  0.772631816537492       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           2           3           5
  0.838583550164614       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           2           4           2
 !!! c6 symmetric dgemm-2           2           4           3
 !!! c6 symmetric dgemm-2           2           4           4
  0.801559198544687       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           2           4           5
  0.945483527728317       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           2           5           2
 !!! c6 symmetric dgemm-2           2           5           3
 !!! c6 symmetric dgemm-2           2           5           4
 !!! c6 symmetric dgemm-2           2           5           5
   1.01922577710048       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           3           2           2
   1.21501967341257       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           3           2           3
  0.751368628288491       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           3           2           4
   1.20695111834953       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           3           2           5
  0.768640451902166       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           3           3           2
 !!! c6 symmetric dgemm-2           3           3           3
   1.24850494613211       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           3           3           4
   1.02216928236875       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           3           3           5
   1.02297953612829       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           3           4           2
 !!! c6 symmetric dgemm-2           3           4           3
 !!! c6 symmetric dgemm-2           3           4           4
  0.854921457179884       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           3           4           5
   1.51419329132511       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           3           5           2
 !!! c6 symmetric dgemm-2           3           5           3
 !!! c6 symmetric dgemm-2           3           5           4
 !!! c6 symmetric dgemm-2           3           5           5
   1.05841684139229       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           4           2           2
   2.42535630024303       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           4           2           3
   1.47908052253849       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           4           2           4
   1.92820282226805       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           4           2           5
   1.89486126875148       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           4           3           2
 !!! c6 symmetric dgemm-2           4           3           3
   3.14610468834190       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           4           3           4
   2.08679999203636       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           4           3           5
   2.07491602246583       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           4           4           2
 !!! c6 symmetric dgemm-2           4           4           3
 !!! c6 symmetric dgemm-2           4           4           4
   1.56443083824290       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           4           4           5
   2.79345022032791       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           4           5           2
 !!! c6 symmetric dgemm-2           4           5           3
 !!! c6 symmetric dgemm-2           4           5           4
 !!! c6 symmetric dgemm-2           4           5           5
   2.03919814673137       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           5           2           2
   1.37501064481411       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           5           2           3
   1.02125298029307       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           5           2           4
   1.50769866614544       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           5           2           5
  0.959930544467842       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           5           3           2
 !!! c6 symmetric dgemm-2           5           3           3
   1.98036308866278       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           5           3           4
   1.18770561844815       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           5           3           5
   1.43258214875474       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           5           4           2
 !!! c6 symmetric dgemm-2           5           4           3
 !!! c6 symmetric dgemm-2           5           4           4
   1.19745384959945       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           5           4           5
   1.96112789765020       0.000000000000000E+000
 !!! c6 symmetric dgemm-2           5           5           2
 !!! c6 symmetric dgemm-2           5           5           3
 !!! c6 symmetric dgemm-2           5           5           4
 !!! c6 symmetric dgemm-2           5           5           5
   1.32984150498105       0.000000000000000E+000
both 124 and 142 are there. I am very sorry for this issue.
AlphaF20
Hi @Peter_C_Intel ,
  Seems I got a fix!
  do ld = 1, nd
  enddo
the index between na and nb should *not* be 1. Replace it as ld seems to work
  do ld = 1, nd
     Call dgemm( 'N', 'N', na, ld, nb, 1.0_wp, a , Size( a , Dim = 1 ), &
  enddo
and got faster
 na, nb, nc, nd ?
100 100 100 100
 Time for straight dgemm  2.426400000000000E-002
 Time for symmetric dgemm-2  6.451000000000000E-003
Thank you so much! You made my day!
