7303 Discussions
Issue during replacing ipp DCT function with MKL DCT function
Ashwin_A_1
I want to replace my IPP based DCT function with mkl based DCT function .
I am getting different output data when I will cross check with the ipp DCT vs mkl DCT function output.
I used below functions to get the DCT by usng IPP.lib function calls :
ippsDCTFwdInitAlloc_32f
ippsDCTFwd_32f
ippsDCTFwdFree_32f
Below is my code :
//pfa of the fileinput.txt
int main(int argc, char* argv[]){
    float *dpar;
    float *out;
    MKL_INT    *ipar;
    MKL_INT tt_type,stat,n_1,nn;
    FILE *fp,*fw,*fonce;
    fp = fopen( "D:\\dump\\fileinput.txt","r" );
    if(fp == NULL){
        cout<<"file not created properly"<<endl;
    DFTI_DESCRIPTOR_HANDLE handle = 0;
    int n = 65; //Hardcoded to run for my code TODO:going to change after integrating into my main codebase
    nn = (MKL_INT)n;
    tt_type = MKL_STAGGERED_COSINE_TRANSFORM;
    n_1 = nn + 1 ;
    out = (float*)malloc((n+1)*sizeof(float));
    dpar= (float*)malloc((5*n_1/2+2)*sizeof(float));
    ipar= (MKL_INT*)malloc((128)*sizeof(int));
    s_init_trig_transform(&n_1,&tt_type,ipar,dpar,&stat);
    for (int srcSize =0 ;srcSize< n ; srcSize++)
        fscanf(fp,"%f\n",&out[srcSize]);
    fclose(fp);
    if (stat != 0)
        printf("\n============================================================================\n");
        printf("FFTW2MKL FATAL ERROR: MKL TT initialization has failed with status=%d\n",(MKL_INT)stat);
        printf("Please refer to the Trigonometric Transform Routines Section of MKL Manual\n");
        printf("to find what went wrong...\n");
        printf("============================================================================\n");
        return NULL;
    ipar[10] = 1;    //nx, that is, the number of intervals along the x-axis, in the Cartesian case.
    ipar[14] = n_1;  //specifies the internal partitioning of the dpar array.
    ipar[15] = 1;    //value of ipar[14]+1,Specifies the internal partitioning of the dpar array.
    s_commit_trig_transform(out,&handle,ipar,dpar,&stat);
    if (stat != 0)
        printf("FFTW2MKL FATAL ERROR: MKL TT commit step has failed with status=%d\n",(MKL_INT)stat);
        return NULL;
    s_forward_trig_transform(out,&handle,ipar,dpar,&stat);
    if (stat != 0)
        return NULL;
    free_trig_transform(&handle,ipar,&stat);
    printf("\n===== DCT GOT OVER ======== \n");
    return 0;
Ashwin_A_1
More update :
 I took 8x8 Matrix as input to to above mentioned code with tt_type = MKL_COSINE_TRANSFORM;
255    255    255    255    255    255    255    255
DCT from  above code is wrongly came as -
32385             -727.349243     -619.955444    -458.675903    -267.323547    -74.151535     92.318069       207.505844
764.404419     717.50531       602.316772      435.846893     242.6754          51.322887    -109.956779    -217.350159
-762.619629    -706.582764    -583.869446    -412.598663    -218.058334    -28.972321    126.74057       226.088898
759.648132     694.603516     564.651367      388.979492    193.525208      7.147152      -142.635284     -233.70639
-755.498901    -681.59967     -544.712891    -365.049927    -169.138          14.096443     157.598663     240.180206
750.180115     667.597656     524.094971     340.860809    144.948898    -34.714363    -171.600922     -245.499771
-743.705566    -652.633789    -502.85144     -316.473694    -121.019257    54.652824    184.604614     249.648224
736.088623     636.739502     481.026154     291.940552     97.400169    -73.870857    -196.583725     -252.620102
It is totally wrong .
Can anyone tell me the mistake in my above code .
Please make a note that I did Direct DCT by initializing tt_type = MKL_COSINE_TRANSFORM;
Ying_H_Intel
Hi Ashwin,
Just let you  know, I'm investigating the problem with our developer, but may be a little delay as new year holiday.  Sorry for the delay
Happy new year!
Ying
Ying_H_Intel
Hi Ashwin,
We find the problem:
the n_1  in init functionality – number of intervals, for cosine transform.  So  it is equal number of points minus one.
if you try the below fix,
int n = 64; //Hardcoded to run for my code TODO:going to change after integrating into my main codebase
    nn = (MKL_INT)n;
    tt_type = MKL_COSINE_TRANSFORM; ;
    n_1 = n - 1 ;
You will get the correct result.
 Ipar[10] and other  are internal parameters, we didn’t allow to change them.
 pDst 16065.000000
pDst 0.000000
pDst 0.000122
pDst 0.000052
pDst 0.000000
pDst 0.000052
pDst 0.000036
pDst 0.000145
pDst -0.000002
pDst 0.000220
But please notes  It is at 8 time greater than ipp one because ipp result is divided by sqrt N.
Ying
and in case if  you want to use theMKL_STAGGERED_COSINE_TRANSFORM,  according the documents,
/f[64] for staggered cosine transforms = 0;
int n = 65;
//; // MKL_COSINE_TRANSFORM; //MKL_STAGGERED_COSINE_TRANSFORM;
float pSrc[65]={
255,    255 ,   255 ,   255 ,   255 ,   255,    255 ,   255,
255 ,   255 ,   255 ,   255  ,  255  ,  255 ,   255,    255,
255 ,   255 ,   255,    255 ,   255 ,   255 ,   255,    255,
255,    255 ,   255 ,   255,    255 ,   255  ,  255 ,   255,
255 ,   255,    255 ,   255 ,   255  ,  255 ,   255 ,   255,
255 ,   255,    255,    255,    255,   255  ,  255  ,  255,
255,    255 ,   255 ,   255 ,   255,    255 ,   255 ,   255,
255,    255,    255,    255,    255,    255,    255,    255,
0};
    n_1 = n - 1 ;
s_init_trig_transform(&n_1,&tt_type,ipar,spar,&stat);
Palanivel_G_
Hi Ying,
I tried your suggested fixes and below are the comparative results between IPP and MKL implementations.
Input : 8x8 with all elements 255
IPP Output:
2040    0    0    0    0    0    0    0
0    0    0    0    0    0    0    0
0    0    0    0    0    0    0    0
0    0    0    0    0    0    0    0
0    0    0    0    0    0    0    0
0    0    0    0    0    0    0    0
0    0    0    0    0    0    0    0
0    0    0    0    0    0    0    0
MKL Output:
510    0    -2.12484e-007    -8.95694e-008    2.02821e-006    1.98985e-006    -2.44188e-007    1.36767e-006
1.25338e-008    8.65079e-007    -4.82064e-007    1.93344e-006    2.85854e-008    1.90692e-006    0    1.90692e-006
-2.95537e-008    1.90544e-006    6.00573e-007    2.19466e-006    -1.37825e-007    2.03849e-006    -6.08452e-008    1.85739e-006
-3.83681e-008    2.36938e-006    8.6844e-009    2.35244e-006    0    2.35244e-006    -1.61479e-008    2.35742e-006
4.02007e-007    2.39765e-006    -1.16682e-007    2.33411e-006    -7.94424e-008    2.23449e-006    9.64763e-008    2.57738e-006
1.70139e-009    2.56381e-006    0    2.56381e-006    -1.02961e-008    2.57161e-006    3.07488e-007    2.49331e-006
-1.0582e-007    2.47736e-006    -8.96722e-008    2.42256e-006    1.75386e-007    2.66651e-006    -2.62343e-009    2.65502e-006
0    2.65502e-006    -6.2848e-009    2.66475e-006    2.39635e-007    2.50137e-006    -9.76727e-008    2.52111e-006
The output is ~4 times lesser than the DCT output.
Could you please let me know what is going on wrong here?.
The code snippet used in MKL are as below,
    int n = 64; // 8x8 input, so 64 co-efficients
    nn = (MKL_INT)n;
    n_1 = n - 1 ; // no of intervals
    out = (float*)   malloc ((n + 1) * sizeof(float));
    dpar= (float*)   malloc (((5 * (n_1 / 2)) + 2) * sizeof(float));
    ipar= (MKL_INT*) malloc ((128) * sizeof(int));
    s_init_trig_transform(&n_1, &tt_type, ipar, dpar, &stat);
    ** Populate the input
    for (int k = 0; k < n; k++) {
           out = 255.0;
    Thanks in advance.
Best regards
Palanivel
Ying_H_Intel
Hi Palanivel,
I upload the whole cpp file. You may check what is difference for the result.  (sorry, I upload again)
Ying
Palanivel_G_
Hi Ying,
Thanks for the reply.
Request you to please upload the complete cpp file.
Palanivel
Ying_H_Intel
Hi Palanivel,
I attached the test code with MKL_COSINE_TRANSFORM  in # 6   and theMKL_STAGGERED_COSINE_TRANSFORM  in this reply.
Ying
