Issue with intel pardiso (oneapi mkl)
a_piquet
I'm trying to use the pardiso solver for my code so I tested some example and the results given by those test are wrong.
I have tested this file (which comes from the MKL example database) :
https://github.com/ww382/CS5220FinalProject/blob/master/pardiso_sym_c.c
This file solve the Ax=b equation with A a sparse matrix (8x8). So at the end I can check the answer given by Pardiso (x) by multiplying A*x and this does not give b ==> A*xpardiso /= b
I have also used Matlab to check the results (x=A\b) and the result is not the same than given by Pardiso.
The pardiso_sym_c.c file is compiled with OneAPI 2023 using :
icc pardiso_sym_c.c -lmkl_sequential -lmkl_core -lmkl_intel_lp64
Is there something I don't do correctly?
Thank you
A =
7. 0. 1. 0. 0. 2. 7. 0.
0. -4. 8. 0. 2. 0. 0. 0.
0. 0. 1. 0. 0. 0. 0. 5.
0. 0. 0. 7. 0. 0. 9. 0.
0. 0. 0. 0. 5. 1. 5. 0.
0. 0. 0. 0. 0. -1. 0. 5.
0. 0. 0. 0. 0. 0. 11. 0.
0. 0. 0. 0. 0. 0. 0. 5.
b =
1.
1.
1.
1.
1.
1.
1.
1.
A\b (from matlab) =  0.0519481
-0.1954545
0.
0.0259740
0.1090909
5.551D-17
0.0909091
0.2
while Pardiso give me :
xpardiso=
-0.041860
-0.003413
 0.117250
-0.112640
 0.024172
-0.107633
 0.198720
 0.190383
a_piquet
My bad, the matrix is symmetric so I miss the other part of the symmetry to compute my array... No problem in pardiso
You can close the thread. Sorry.
a_piquet
Strange,
When i change the matrix mtype from "Real symmetric matrix" to "real and nonsymmetric", it works. The matrix is symmetric though so...
//MKL_INT mtype = -2;
MKL_INT mtype = 11;
a_piquet
ShanmukhS_Intel
Hi Arthur,
It’s great to know that the issue has been resolved, in case you run into any other issues please feel free to create a new thread.
Shanmukh.SS
