7302 Discussions
Iterative Sparse Solvers based on Reverse Communication Interface
Hoang__Dat
Dear Sir/Madam,
I am grateful for the development of Intel Visual Fortran Compiler for Windows. It helps my work a lot.
I would like to ask about RCI ISS in the newest Intel MKL solver. I know that in Intel MKL, there is an RCI conjugate gradient solver.
Hence, does it work well with EBE-PCG (element by element preconditioner conjugate gradient) method or can I build my code for EBE-PCG method using Intel MKL solver?
Thank you very much!
Tien-Dat
Ying_H_Intel
Hi Tien-Dat,
Thank you for raising the question. As i understand, you may use some of  MKL functions for example, sparse solver, sparse matrix * vector for your method.
Here is the functionality and example code for the RCI ISS in MKL developer guide for your reference
https://software.intel.com/en-us/mkl-developer-reference-fortran-sparse-solver-routines
​Ying​
Hoang__Dat
Dear Sir. Ying,
Thank you very much for your sharing information. I will try to follow the guide to solve my problem. However, I think it is not easy for me to solve it without any mistake.
I hope I will receive more your suggestions in the future.
Yours sincerely,
Tien-Dat
