LAPACK_zheev with matrix_layout=LAPACK_ROW_MAJOR
kumar__prashant
There seems to be a bug in the routine LAPACK_zheev in MKL 2019 update 3 version. This routine is used for finding eigenvectors and eigenvalues of a Hermitian matrix 'a'. Its syntax is:
lapack_int LAPACKE_zheev ( int matrix_layout , char jobz , char uplo , lapack_int n , lapack_complex_double* a , lapack_int lda , double* w );
The problem seems to occur for only "matrix_layout = LAPACK_ROW_MAJOR" argument with jobz = 'V'. The eigenvectors are outputted in 'a' by rewriting it. However, the routine rewrites only upper triangular portion of 'a' and the rest of the matrix is unchanged.
For example, the following code calculates the eigenvectors of the 2x2 Pauli matrix sigma_x.
filename: lapack_zheev
#include <iostream>
#include <complex>
#define MKL_Complex16 std::complex<double>
#include "mkl.h"
#include "mkl_types.h"
using namespace std;
int main() {
    complex<double> a[4];
    a[0] = 0;
    a[1] = 1;
    a[2] = 1;
    a[3] = 0;
    double eigs[2];
    int info = LAPACKE_zheev(LAPACK_ROW_MAJOR, 'V', 'U', 2, a, 2, eigs);
    cout << "Info = " << info << endl;
    cout << a[0] << " " << a[1] << endl;
    cout << a[2] << " " << a[3] << endl;
I compile it with:
icpc -std=c++14 -qopenmp -DMKL_ILP64 -m64 -I${MKLROOT}/include -O3 -DNDEBUG -ansi-alias -o lapack_zheev.out lapack_zheev.cpp -Wl,--start-group ${MKLROOT}/lib/intel64/libmkl_intel_ilp64.a ${MKLROOT}/lib/intel64/libmkl_intel_thread.a ${MKLROOT}/lib/intel64/libmkl_core.a -Wl,--end-group -liomp5 -lpthread -lm -ldl
./lapack_zheev.out
The output is:
Info = 0
(-0.707107,0) (0.707107,0)
(1,0) (0.707107,0)
while it is supposed to be:
Info = 0
(0.707107,0)   (0.707107,0)
Replacing LAPACK_ROW_MAJOR by LAPACK_COL_MAJOR produces the correct output.
Gennady_F_Intel
Yes, this is an known issue which was introduced the last update. We will fix this into on the future updates. As a work-around - please try e.x the version of MKL  2019.0.
We will keep this tread updated when the fix of the problem will be available into product version of MKL.
Gennady_F_Intel
the small remark - the latest correct update - MKL 2019 u1.
Mishra__Ashirbad
Even in the older version of MKL there is bug which gives incorrect values when using LAPACK_ROW_MAJOR. In the version 18.04 that I am using the signs (+/-) of the elements of the matrix are incorrect, even though the absolute values are correct. The incorrectness is not uniform, i.e I can't take the negative(-) of the elements to reverse their signs to the correct values.
However, the only configuration that works is LAPACK_COLUMN_MAJOR.
Gennady_F_Intel
please try to check version 2019 u4
