ScaLAPACK crash using different block sizes
kalen__stoi
I would like to use pzgesv routine to solve system of linear equations but it crashes if use block size 64 and e.g. with two processes
it doesn't crash if i run the program with mpirun -np 1 ./myapp, or the block size is 4 and any number of processes.
number of rows = 116, nrhs = 4; openmpi, mpicxx -v: gcc version 7.4.0
here is the backtrace:
from the gdb
process 1
Thread 1 "myapp" received signal SIGSEGV, Segmentation fault.
0x00007ffff67483b2 in PMPI_Comm_size ()
   from /usr/lib/x86_64-linux-gnu/libmpi.so.20
(gdb) bt
#0  0x00007ffff67483b2 in PMPI_Comm_size ()
#1  0x000055555897967a in MKLMPI_Comm_size ()
#2  0x000055555568884c in PB_CpgemmMPI ()
#3  0x000055555564e916 in pzgemm_ ()
#4  0x00005555556355b0 in pzgetrf2_ ()
#5  0x0000555555634aaf in pzgetrf_ ()
#6  0x000055555562c60d in pzgesv_ ()
#7  0x00005555555ed944 in main (argc=1, argv=0x7fffffffd6e8)
    at Main.cpp:159
process 0
(gdb) bt
    at Main.cpp:159
the descriptors and data looks OK.
any idea what is going on?
sk
Gennady_F_Intel
Could you give us the reproducer which we may compile and run on our side?
kalen__stoi
it is not exactly the same code that gives the previous backtrace but the following one give similar behavior when I set the blocksize (Mb=64) it fails and pass with Mb=2
#include <iostream>
#include <memory>
#include <complex>
#include <mpi.h>
#include <mkl.h>
#include <complex>
#include <mkl_scalapack.h>
extern "C"
/* BLACS C interface */
void Cblacs_pinfo(int* mypnum, int* nprocs);
void Cblacs_get( MKL_INT context, MKL_INT request, MKL_INT* value);
int  Cblacs_gridinit( MKL_INT* context, char * order, MKL_INT np_row, MKL_INT np_col);
void Cblacs_gridinfo( MKL_INT context, MKL_INT*  np_row, MKL_INT* np_col, MKL_INT*  my_row,
                      MKL_INT*  my_col);
void Cblacs_gridexit(MKL_INT ictxt);
void Cblacs_barrier(MKL_INT ictxt, char * order);
void Cblacs_exit(int);
void Czgerv2d(int, int, int, std::complex<double>*, int, int, int);
void Czgesd2d(int, int, int, std::complex<double>*, int, int, int);
void Cdgerv2d(int, int, int, double*, int, int, int);
void Cdgesd2d(int, int, int, double*, int, int, int);
int main(int argc, char ** argv)
    int dims[] = {0, 0};
    int myid, nprocs;
    MKL_INT nprows, npcols, context, myrow, mycol;
    Cblacs_pinfo(&myid, &nprocs);
    MPI_Dims_create(nprocs, 2, dims);
    nprows = (MKL_INT)dims[0];
    npcols = (MKL_INT)dims[1];
    int negone = -1, zero = 0, one = 1;
    Cblacs_get(negone, zero, &context);   //default system context.
    char row_major[] = "Row";
    Cblacs_gridinit(&context, row_major, nprows, npcols);
    Cblacs_gridinfo(context, &nprows, &npcols, &myrow, &mycol);
    MKL_INT Mb = 64, M = 9, nrhs = 1;
    MKL_INT myone = 1, info=0;
    auto lnrows = numroc_ (&M, &Mb, &myrow, &zero, &nprows);
    auto lncols = numroc_ (&M, &Mb, &mycol, &zero, &npcols);
    //GLOBAL
    std::complex<double> * A;
    A = new std::complex<double> [81] {19,3,1,12,1,16,1,3,11,-19,3,1,12,1,16,1,3,11,-19,-3,1,12,1,16,1,3,11,-19,-3,-1,12,1,16,1,3,11,-19, \
    -3,-1,-12,1,16,1,3,11,-19,-3,-1,-12,-1,16,1,3,11,-19,-3,-1,-12,-1,-16,1,3,11,-19,-3,-1,-12,-1,-16,-1,3,11,-19, \
    -3,-1,-12,-1,-16,-1,-3,11};
    //LOCAL
    auto a = new std::complex<double> [lnrows*lncols]();
    for(int lr=0;lr < lnrows; ++lr) {
        int gr = lr % Mb + Mb * myrow + (lr / Mb) * Mb * nprows;
        for (int lc = 0; lc < lncols; ++lc) {
            int gc = lc % Mb + Mb * mycol + (lc / Mb) * Mb * npcols;
            a[lr + lnrows * lc] = A[gr * M + gc]; //col-major <- row-major
    std::complex<double> * B = new std::complex<double> [9] {0,0,1,0,0,0,0,0,0};
    auto b = new std::complex<double> [lnrows*lncols]();
        b[lr] = B[gr]; //col-major <- row-major
    MKL_INT* ipiv = new MKL_INT [lncols*M + Mb]();
    MKL_INT desca[9];
    desca[0] = 1; // descriptor type
    desca[1] = context; // blacs context
    desca[2] = M; // global numberh of rows
    desca[3] = M; // global number of columns
    desca[4] = Mb; // row block size
    desca[5] = Mb; // column block size
    desca[6] = 0; // initial process row
    desca[7] = 0; // initial process column
    desca[8] = lnrows; // leading dimension of local array
    MKL_INT descb[9];
    descb[0] = 1; // descriptor type
    descb[1] = context; // blacs context
    descb[2] = M; // global numberh of rows
    descb[3] = nrhs; // global number of columns
    descb[4] = Mb; // row block size
    descb[5] = Mb; // column block size
    descb[6] = 0; // initial process row
    descb[7] = 0; // initial process column
    descb[8] = lnrows; // leading dimension of local array
    std::cout << "lnrows=" << lnrows << " nprows=" << nprows<< " npcols=" << npcols<< std::endl;
    pzgesv_(&M, &nrhs, (MKL_Complex16*)a, &myone, &myone, desca,ipiv,
            (MKL_Complex16*)b, &myone, &myone, descb, &info);
    if(info != 0) {
        std::cout << "PDGESV problem! Info " << info << std::endl;
    for(int i=0; i< lnrows; ++i){
       std::cout << " sol[" << i << "]= " << b.real() <<std::endl;
    delete [] ipiv;
    Cblacs_barrier(context, "All");
    Cblacs_gridexit(context);
    Cblacs_exit(0);
    return 0;
Gennady_F_Intel
to be exactly on the same page, please show how did you link and which version of mpi do you use?
kalen__stoi
it is cmake project:
target_link_libraries(main PRIVATE nlohmann_json::nlohmann_json -Wl,--start-group $ENV{MKLROOT}/lib/intel64/libmkl_scalapack_lp64.a $ENV{MKLROOT}/lib/intel64/libmkl_blacs_openmpi_lp64.a $ENV{MKLROOT}/lib/intel64/libmkl_intel_lp64.a $ENV{MKLROOT}/lib/intel64/libmkl_gnu_thread.a $ENV{MKLROOT}/lib/intel64/libmkl_core.a -Wl,--end-group -lgomp -lpthread -lm -ldl ${HDF5_C_LIBRARIES} ${Boost_LIBRARIES} )
mpirun -V
mpirun (Open MPI) 2.1.1
there is no problem when compile and linking.
