7303 Discussions
LNK1103 error, recompile module mkl_core.lib
John_L_4
All the info about which version of which compilers I have is at the bottom of the thread.
All I'm trying to do is compile and link one of the MKL examples for a 2D FFT. Here is the code:
program
test
! Fortran
use
mkl_dfti
Complex
:: X_2D(20,40)
Complex
:: X(800)
Equivalence
(X_2D, X)
INTEGER
:: STRIDE(2)
type
(DFTI_DESCRIPTOR), POINTER :: Desc_Handle_Dim1
type
(DFTI_DESCRIPTOR), POINTER :: Desc_Handle_Dim2
Status = DftiCreateDescriptor(Desc_Handle_Dim1, DFTI_SINGLE,&
DFTI_COMPLEX, 1, 20 )
Status = DftiCreateDescriptor(Desc_Handle_Dim2, DFTI_SINGLE,&
DFTI_COMPLEX, 1, 40 )
! perform 40 one-dimensional transforms along 1st dimension
Status = DftiSetValue( Desc_Handle_Dim1, DFTI_NUMBER_OF_TRANSFORMS, 40 )
Status = DftiSetValue( Desc_Handle_Dim1, DFTI_INPUT_DISTANCE, 20 )
Status = DftiSetValue( Desc_Handle_Dim1, DFTI_OUTPUT_DISTANCE, 20 )
Status = DftiCommitDescriptor( Desc_Handle_Dim1 )
Status = DftiComputeForward( Desc_Handle_Dim1, X )
! perform 20 one-dimensional transforms along 2nd dimension
Stride(1) = 0; Stride(2) = 20
Status = DftiSetValue( Desc_Handle_Dim2, DFTI_NUMBER_OF_TRANSFORMS, 20 )
Status = DftiSetValue( Desc_Handle_Dim2, DFTI_INPUT_DISTANCE, 1 )
Status = DftiSetValue( Desc_Handle_Dim2, DFTI_OUTPUT_DISTANCE, 1 )
Status = DftiSetValue( Desc_Handle_Dim2, DFTI_INPUT_STRIDES, Stride )
Status = DftiSetValue( Desc_Handle_Dim2, DFTI_OUTPUT_STRIDES, Stride )
Status = DftiCommitDescriptor( Desc_Handle_Dim2 )
Status = DftiComputeForward( Desc_Handle_Dim2, X )
Status = DftiFreeDescriptor( Desc_Handle_Dim1 )
Status = DftiFreeDescriptor( Desc_Handle_Dim2 )
end
program test
When I try and compile and link the program in the DEBUG configuration I get the following error:
Error1 fatal error LNK1103: debugging information corrupt; recompile modulemkl_core.lib(pszerow7as_1_1.obj)
The RELEASE version compiles and links just fine (don't care, need to be able to debug).
Please don't refer to http://support.microsoft.com/kb/949009/en-us/.
I have already tried this and it won't install because I have SP2 of VS2005 not SP1.
Compiler Info:
Microsoft Visual Studio 2005
Version 8.0.50727.762 (SP.050727-7600)
Microsoft .NET Framework
Version 2.0.50727 SP2
Installed Edition: Professional
Microsoft Visual Basic 2005 77626-009-0000007-41912
Microsoft Visual C# 2005 77626-009-0000007-41912
Microsoft Visual C++ 2005 77626-009-0000007-41912
Microsoft Visual J# 2005 77626-009-0000007-41912
Microsoft Visual Studio 2005 Tools for Applications 77626-009-0000007-41912
Microsoft Visual Web Developer 2005 77626-009-0000007-41912
Microsoft Web Application Projects 2005 77626-009-0000007-41912
Intel Visual Fortran Package ID: w_fcompxe_2011.1.127
Intel Visual Fortran Composer XE 2011 Integration for Microsoft Visual Studio* 2005, 12.0.3470.2005, Copyright (C) 2002-2010 Intel Corporation
* Other names and brands may be claimed as the property of others.
Microsoft Visual Studio 2005 Professional Edition - ENU Service Pack 1 (KB926601)
This service pack is for Microsoft Visual Studio 2005 Professional Edition - ENU.
If you later install a more recent service pack, this service pack will be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/926601
Security Update for Microsoft Visual Studio 2005 Professional Edition - ENU (KB947738)
This Security Update is for Microsoft Visual Studio 2005 Professional Edition - ENU.
If you later install a more recent service pack, this Security Update will be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/947738
Security Update for Microsoft Visual Studio 2005 Professional Edition - ENU (KB971023)
For more information, visit http://support.microsoft.com/kb/971023
Security Update for Microsoft Visual Studio 2005 Professional Edition - ENU (KB971090)
For more information, visit http://support.microsoft.com/kb/971090
Security Update for Microsoft Visual Studio 2005 Professional Edition - ENU (KB973673)
For more information, visit http://support.microsoft.com/kb/973673
TimP
The MKL library doesn't supply .pdb information. This shouldn't stop you from debugging, as long as you understand there's no source information should you step into the MKL library.
Evgueni_P_Intel
Hi
John_L_4
I installed 10.3.2 and it doesn't help. Here are the build and link lines.
Build:
/nologo /debug:full /Od /warn:interfaces /module:"Debug\" /object:"Debug\" /traceback /check:bounds /libs:static /threads /dbglibs /c
Link:
/OUT:"Debug\fft.exe" /INCREMENTAL:NO /NOLOGO /MANIFEST /MANIFESTFILE:"C:\Documents and Settings\lansbje1\My Documents\temp\pbj\fft\Debug\fft.exe.intermediate.manifest" /DEBUG /PDB:"C:\Documents and Settings\lansbje1\My Documents\temp\pbj\fft\Debug\fft.pdb" /SUBSYSTEM:CONSOLE /IMPLIB:"C:\Documents and Settings\lansbje1\My Documents\temp\pbj\fft\Debug\fft.lib" mkl_intel_c.lib mkl_intel_thread.lib mkl_core.lib libiomp5md.lib
Code:
program
test
! Fortran
use
mkl_dfti
Complex
:: X_2D(20,40)
Complex
:: X(800)
Equivalence
(X_2D, X)
INTEGER
:: STRIDE(2)
type
type
end
program test
This is just straight from the MKL example code for Fortran.
Error message:
Error1 fatal error LNK1103: debugging information corrupt; recompile modulemkl_core.lib(pszerow7as_20101122.obj)
Gennady_F_Intel
Hello John,
Could you look at the look at the post :
the hot fix available there.
let us know if it helps you.
--Gennady
John_L_4
As noted in my original post (sorry, should have put it right up front), I already tried the hot fix and it would not install because I have SP2 of VS2005, not SP1. So, the hot fix is no use to me.
John_L_4
My apologies. I was misreading the version installation of my VS2005. I don't believe there is a SP2 for VS2005. I need to double check my version and make sure I have SP1 installed. If not, I will install and see if that fixes the problem. If not, I'll re-try the hot fix.
