7302 Discussions
Library not loaded: libmkl_intel_ilp64.dylib
emartihu
Hello everyone,
I'm new in mac and with IMKL too, trying to get up some f90 codes for signal processing in a
Macmini3,1. 1Proc, two cores (In the near future we expected to run our applications in a cluster of similar Macs).
After a while I was able to compile without errors, nevertheless the executable doesn't run. Showing the error in the thread title. Here down details:
MKLPATH=/Developer/opt/intel/Compiler/11.1/088/Frameworks/mkl/lib/em64tMKLINCLUDE=/Developer/opt/intel/Compiler/11.1/088/Frameworks/mkl/include/em64t/ilp64Script:ifort -o exec $1 $2 -L MKLPATH -I MKLINCLUDE/Developer/opt/intel/Compiler/11.1/088/Frameworks/mkl/lib/em64t/libmkl_intel_ilp64.dylib /Developer/opt/intel/Compiler/11.1/088/Frameworks/mkl/lib/em64t/libmkl_intel_thread.dylib /Developer/opt/intel/Compiler/11.1/088/Frameworks/mkl/lib/em64t/libmkl_core.dylib /Developer/opt/intel/Compiler/11.1/088/lib/libiomp5.dylib -openmp -lpthreadwhen you execute your recently compiled file, the following output is shown:dhcp-0083712665-16-41:FFT_INTEL_MAC erwin$ ./execdyld: Library not loaded: libmkl_intel_ilp64.dylibReferenced from: /Users/erwin/Desktop/FFT_INTEL_MAC/./execReason: image not foundTrace/BPT trapdhcp-0083712665-16-41:FFT_INTEL_MAC erwin$ ./execdyld: Library not loaded: libmkl_intel_ilp64.dylibReferenced from: /Users/erwin/Desktop/FFT_INTEL_MAC/./execReason: image not foundTrace/BPT trap___I'll thank any help or comment you can share with me.In advance thanks a lot.C. Evans
Todd_R_Intel
Have you setDYLD_LIBRARY_PATH to point to the directory location of the Intel MKL dylib's?
Example:
export DYLD_LIBRARY_PATH=/Developer/opt/intel/Compiler/11.1/088/Frameworks/mkl/lib/em64t/
Todd
emartihu
Hello Todd,
Thank you for your answer, I already included this path and the compilation is going well, but now when Im trying to run de application the following output is obtained:
dhcp-0083712665-16-41:FFT_INTEL_MAC$ ./exec
dyld: Library not loaded: libiomp5.dylib
Referenced from: /Users/rwm/Desktop/FFT_INTEL_MAC/./exec
Trace/BPT trap
I looked for this particular library to address the compilation to take into account it, and there are
sh-3.2# find / -name libiomp5.dylib -print
/Applications/MATLAB_R2009b.app/bin/maci/libiomp5.dylib
/Applications/MATLAB_R2009b.app/bin/maci64/libiomp5.dylib
find: /dev/fd/3: Not a directory
find: /dev/fd/4: Not a directory
/Library/Frameworks/Intel_MKL.framework/Versions/10.0.5.025/lib/32/libiomp5.dylib
/Library/Frameworks/Intel_MKL.framework/Versions/10.0.5.025/lib/em64t/libiomp5.dylib
/Library/Frameworks/Intel_MKL.framework/Versions/10.0.5.025/lib/universal/libiomp5.dylib
I tried to compile pointing out to all of these paths, nothing worked. So I copied the libiomp5.dylib file to the folder
and now I was able to compile with out errors. Nevertheless there are some run time errors:
dhcp-0083712665-16-41:FFT_INTEL_MAC $ ./exec
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image PC Routine Line Source
libmkl_intel_ilp6 0000000100109196 Unknown Unknown Unknown
libmkl_intel_ilp6 0000000100108DB6 Unknown Unknown Unknown
exec 0000000100001B25 Unknown Unknown Unknown
exec 00000001000016EC Unknown Unknown Unknown
exec 0000000100001684 Unknown Unknown Unknown
One of the probs could be that the libiomp5.dylib is not loaded into the OS. Doing this with ld.so.conf + ldconfig in linux is extremely easy, but I dont know how to do this in Mac OS X.
Any advise will be very welcome!
Thank you for your attention.
Best
Evns
nousername
barragan_villanueva_
Valued Contributor I
In OSX* there are fat MKL libraries, so please set DYLD_LIBRARY_PATH to MKL lib location without arch-specific word just .../mkl/lib
Jonathan_S_1
Hi all sorry to bother you but I'm having similar problems.
I get this error when running first v 12
So I tried fixing it by entering this into the console
DYLD_LIBRARY_PATH="/opt/intel/composer_xe_2013_sp1.1.103/compiler/lib"
but no luck.
any hints would be much appreciated
