Link issue for parallel oneMKL
LaurentPlagne
I am able to compile the joined snippet with the sequential version of oneMKL
dpcpp -O3 -fsycl -std=c++17 -DMKL_ILP64 -g -DNDEBUG -lOpenCL -lsycl -lmkl_sycl -lmkl_core -lmkl_sequential -lmkl_intel_lp64 ../src/portable_main.cpp
but it fails when I try to use the parallel version. I tried to follow this  for the link options;
dpcpp  -lmkl_sycl -lmkl_intel_ilp64 -lmkl_tbb_thread -lmkl_core -lsycl -lOpenCL -ltbb -lpthread -ldl -lm ../src/portable_main.cpp
which results in numerous undefined references :
/usr/bin/ld : /opt/intel/oneapi/mkl/2021.1-beta08/lib/intel64/libmkl_tbb_thread.so : référence indéfinie vers « tbb::detail::r1::wait_bounded_queue_monitor(tbb::detail::r1::concurrent_monitor*, unsigned long, long, tbb::detail::d1::delegate_base&) »
/usr/bin/ld : /opt/intel/oneapi/mkl/2021.1-beta08/lib/intel64/libmkl_tbb_thread.so : référence indéfinie vers « tbb::detail::r1::execute_and_wait(tbb::detail::d1::task&, tbb::detail::d1::task_group_context&, tbb::detail::d1::wait_context&, tbb::detail::d1::task_group_context&) »
/usr/bin/ld : /opt/intel/oneapi/mkl/2021.1-beta08/lib/intel64/libmkl_tbb_thread.so : référence indéfinie vers « tbb::detail::r1::cache_aligned_deallocate(void*) »
/usr/bin/ld : /opt/intel/oneapi/mkl/2021.1-beta08/lib/intel64/libmkl_tbb_thread.so : référence indéfinie vers « tbb::detail::r1::terminate(tbb::detail::d1::task_arena_base&) »
Here is the file portable_main.cpp
#include <fstream>
#include <iostream>
#include <CL/sycl.hpp>
#include <chrono>
#include <cmath>
#include <cstring>
#include <stdio.h>
#include <iostream>
#include <random>
#include <fstream>
#include <chrono>
#include "mkl_sycl.hpp"
#include "dpc_common.hpp"
using namespace cl::sycl;
using namespace std;
constexpr size_t NITER=100; //amortize device/host communication
using Scalar=float;
template <class T>
void bench_axpy(size_t N){
  std::vector<T> a(N,1);
  std::vector<T> b(N,2);
  gpu_selector device_selector;
  queue q(device_selector, dpc_common::exception_handler);
  auto start=std::chrono::high_resolution_clock::now();
  {  // Begin buffer scope
    buffer buf_a(&a[0], range(N));// Create buffers using DPC++ class buffer
    buffer buf_b(&b[0], range(N));
    const T alpha=0.5;
    try{
        for (size_t iter=0; iter<NITER; iter++) {
            mkl::blas::axpy(q, N, alpha, buf_a, 1, buf_b, 1);
    catch(cl::sycl::exception const& e) {
        std::cout << "\t\tCaught synchronous SYCL exception during AXPY:\n"
          << e.what() << std::endl;
  auto end = std::chrono::high_resolution_clock::now();
  std::chrono::duration<double> elapsed_seconds = end-start;
  double time = elapsed_seconds.count();
  double GBs=double(3*N)*sizeof(T)*NITER/(time*1.e9);//2R+1W
  std::cout <<"GBs="<<GBs<<std::endl;
int main(int argc, char* argv[]) {
  bench_axpy<float>(2<<27);
  return 0;
GouthamK_Intel
Thanks for reaching out to us!
Since your issue is related to oneMKL, we are moving this query to the Intel® oneAPI Math Kernel Library & Intel® Math Kernel Library forum for a faster response.
Goutham
LaurentPlagne
Do you have a suggestion for this link issue ?
Ruqiu_C_Intel
Dear Laurent Plagne,
Intel oneAPI 2021.1 was officially released in Dec 8th. Have you tried it? And let us know if the link issue is still exist.
Ruqiu
Ruqiu_C_Intel
We will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.  Thanks
