Symbolic factorization in Pardiso
danielsue
Hi All,
I use Pardiso to solve reactive transport problem. I tried to do symbolic factorization at first and then in the following newton iterations, only do numerical factorization and substitution.
For the simple problem, this works fine. But for the complex problem, things are quite different. The results are correct in the beginning, but after many iterations, the result is incorrect with large error. Then I tried to do symbolic factorization every step, it can generate correct results.
The structure of matrix (ia, ja) does not change for the whole simulation, only the coefficient (a) and right hand (b) changes. What's wrong with my setting?
The parameter for pardiso are as follows:
        iparm = 0
        iparm(1) = 1 ! no solver default
        iparm(2) = 3 ! fill-in reordering from METIS ,0-MIN DEGREE, 2-METIS, 3-OPENMP VERSION
        iparm(3) = 0 ! numbers of processors. Input the next call mkl_set_dynamic(0), mkl_set_num_threads(n);
        iparm(4) = 61 ! 0-no iterative-direct algorithm; 10*L+K, K=1 CGS, K=2 CGS for symmetric, 1.0E-L: stopping criterion
        iparm(5) = 0 ! no user fill-in reducing permutation
        iparm(6) = 0 ! if == 0, the array of b is replaced with the solution x.
        iparm(7) = 0 ! Output, Number of iterative refinement steps performed
        iparm(8) = 9 ! numbers of iterative refinement steps, must be 0 if a solution is calculated with separate substitutions (phase = 331, 332, 333)
        iparm(9) = 0 ! not in use
        iparm(10) = 13 ! Default value 13, perturbe the pivot elements with 1E-13
        iparm(11) = 1 ! use nonsymmetric permutation and scaling MPS
        iparm(12) = 0 ! not in use
        iparm(13) = 1 ! maximum weighted matching algorithm is switched-on (default for non-symmetric)
        iparm(14) = 0 ! Output: number of perturbed pivots
        iparm(15) = 0 ! Output, Peak memory on symbolic factorization.
        iparm(16) = 0 ! Output, Permanent memory on symbolic factorization. This value is only computed in phase 1.
        iparm(17) = 0 ! Output, Size of factors/Peak memory on numerical factorization and solution.
        iparm(18) = 0 ! Input/output. Report the number of non-zero elements in the factors. >= 0 Disable reporting.
        iparm(19) = 0 ! Input/output. Report number of floating point operations to factor matrix A. >= 0 Disable reporting.
        iparm(20) = 0 ! Output: Numbers of CG Iterations. >0 CGS succeeded, reports the number of completed iterations.
        iparm(24) = 1 ! Parallel factorization control, 0: classic algorithm, 1: two-level factorization algorithm, improve scalability on many threads.
        iparm(25) = 0 ! Parallel forward/backward solve control. 0: Use parallel algorithm for the solve step; 1: Use the sequential forward/backward solve.
        iparm(27) = 0 !check matrix error, 0-without check, 1-check
        maxfct = 1
        mnum = 1
        nrhs = 1
        error = 0 ! initialize error flag
        msglvl = 0 ! print statistical information
        mtype = 11 ! real unsymmetric
Thanks and regards,
Daniel
Alexander_K_Intel2
The topic is duplicate of http://software.intel.com/en-us/forums/topic/389231#comment-1732291, so I wrote my answer there.
With best regards,
Alexander Kalinkin
mlucio89
I think I encounter the same problem described in this post. However the link to the answer you gave in post 389231 is broken (I am redirected to what looks like a generic search page).
Could you please re-post a working link, or answer again to the question here?
Thank you very much.
ML
Kirill_V_Intel
Please create a separate thread.
First, Alexander is no longer working at Intel.
Second, as I see in this post, the user tried to call Intel(R) MKL PARDISO with API from PARDISO Project. These two are in fact abosultely different software products which have a few things in common. Differences areinside and outside, in the API.
Please read the PARDISO documentation https://software.intel.com/content/www/us/en/develop/documentation/onemkl-developer-reference-c/top/sparse-solver-routines/onemkl-pardiso-parallel-direct-sparse-solver-interface/pardiso.html
and check that you're using the API correctly.
Best,
Kirill
Gennady_F_Intel
mlucio89, did you check the MKL Pardiso API?
mlucio89
Dear @Gennady_F_Intel ,
I finally posted my complete question here:
https://community.intel.com/t5/Intel-oneAPI-Math-Kernel-Library/Intel-MKL-PARDISO-reordering-once-factorizing-multiple-times/td-p/1253109
, as Kirill suggested. In that post, Kirill also provided me with an answer (which, unfortunately, is not yet the solution I was hoping for, but I can live with it for the moment. I keep using MKL PARDISO on a regular basis with good performance).
ML
Gennady_F_Intel
Ok, I see this thread. Then the current one is closing and we will no longer respond to this thread. Any further interaction in this thread will be considered community only.
