Link to MKL
wjiang123
Hi MKL users,
I don't know how to link my program to MKL package. I want to use two libraries, lapack and pardiso, in MKL and try to link it to my program with the following command:
ifort -i8 -o prog prog.f -L /MKL path/ -I /INCLUDE path -Wl,--start-group -lmkl_intel_ilp64.a -lmkl_intel_thread.a -lmkl_solver_ilp64.a -lmkl_lapack.a -Wl
,--end-group -lguide -lpthread -lm&
But obtain the following error:
ld: cannot find -lmkl_intel_ilp64.a
I also set environment variables in ./bashrc, .bash_profile and .profile files, such as PATH, LIB, INCLUDE.
Could someone tell me what is wrong in detail? I am not very familiar with those stuffs. Thanks in advance.
Wen
Vladimir_Petrov__Int
New Contributor III
Quoting - wjiang123
I tried that but still got the same problem: ld: cannot find -lmkl_intel_ilp64.
I also tried to compile the pardiso_unsym_f.f file under the 'examples/solver/source' directory and got the same thing.
Wen,
Please make sure the path /MKL path/ you are using in the link line does contain the required libraries (e.g. libmkl_intel_ilp64.a or libmkl_intel_ilp64.so). Usually such paths look like this:
/opt/mkl100/lib/em64t
-Vladimir
Andrey_G_Intel2
wjiang123,
try to change your command line to following:
ifort -i8 -o prog prog.f -L/MKL path/ -I/INCLUDE path -Wl,--start-group -lmkl_intel_ilp64 -lmkl_intel_thread -lmkl_solver_ilp64 -lmkl_lapack -lmkl_core -Wl,--end-group -lguide -lpthread -lm
in this case dynamic MKL libraries will be used.
Andrey
wjiang123
New Contributor III
Quoting - wjiang123
Wen,
-Vladimir
