Linker problem
Deleted_U_Intel
Dear,
I followed the instructions on http://www.intel.com/cd/ids/developer/asmo-na/eng/index.htmto configure Visual Studio 2003. Compiling cblas_ccopy (on of the examples included), however, fails with the following error message :
VbEen error LNK2019: unresolved external symbol _cblas_ccopy referenced in function _main
VbEen error LNK2019: unresolved external symbol _PrintVectorC referenced in function _main
VbEen error LNK2019: unresolved external symbol _GetVectorC referenced in function _main
The additional dependencies in my project settings are :
mkl_s_dll.lib mkl_p3.lib mkl_lapack.lib
The documentation on http://www.intel.com/cd/ids/developer/asmo-na/eng/index.htmdoes not really explain which additional dependencies should be included.
Do you have any idea what is going wrong ? Does there exist a (detailed) manual which explains how to configure the project settings of Visual Studio ?
Thank you very much,
Bart
Todd_R_Intel
Bart,
I don't see the material you are referencing when I follow the links you provide, but perhaps I can answer some of your questions. Source for the _PrintVectorC and _GetVectorC functions is provided in the file common_func.c which can be found in the examples/cblas/source directory.
Although there isn't a detailed manual, there is some guidance for setting up your Visual C++* .NET settings at http://www.intel.com/support/performancetools/libraries/mkl/win/30486.HTM.
You are most likely getting an error with external symbol _cblas_ccopy because you are linking mkl_s.lib instead of mkl_c.lib. If you have edited your project as directed at the link above then you only need to put mkl_c.lib (or mkl_c_dll.lib) in your dependencies and you should be set.
Todd
