7303 Discussions
Loading MKL slows down other libm function in centos 7.2, 7.3
shuoli
After we load MKL libraries and execute a simple saxby in cblas libs, functions in libm  e.g. lrint becomes 5-10X slower.
This seams to be in Centos 7.2 and 7.3  running on Haswell based CPU such as E5-2640 v4.
We have been using the attached file with gcc to test this issue
It seems MKL loader leaves upper 128 bits of the AVX registers in an unhealthy state and if we call _mm256_zeroupper(); right after loading MKL, the slowness goes away. We still don’t know why the problem only shows up on 7.2 and 7.3.
We can see that, lrint becomes ~6X slower after loading MKL.
-bash-4.2$ /nfs/DEV/PLT/kezhao/test/slowness_mkl_test
handle in 0.128975 sys 0.000000 usr 0.129086 double is 50000000000000.000000
-bash-4.2$ /nfs/DEV/PLT/kezhao/test/slowness_mkl_test /nfs/software/D4C/tflex_d4c_nightly/main/LSF/lib/MKL/4.0/
Succeed to load MKL lib /nfs/software/D4C/tflex_d4c_nightly/main/LSF/lib/MKL/4.0/
handle in 0.768661 sys 0.000000 usr 0.768906 double is 50000000000000.000000
Test environment:
-bash-4.2$ cat /etc/redhat-release
CentOS Linux release 7.3.1611 (Core)
-bash-4.2$ uname -a
Linux dn110706 3.10.0-514.el7.x86_64 #1 SMP Tue Nov 22 16:42:41 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
-bash-4.2$ lscpu|grep Intel
Vendor ID:             GenuineIntel
Model name:            Intel(R) Xeon(R) CPU E5-2640 v4 @ 2.40GHz
Case
OS version
Glibc version
CPU type
MKL preloaded?
Slowness observed?
1
CentOS 7.2
2.17-105
Xeon E5-2640 v4
Yes
Yes
No
No
2
CentOS 7.3
2.17-157
Xeon Gold 6130
Yes
No
No
No
3
CentOS 7.3
2.17-157
Xeon E5-2640 v4
Yes
Yes
No
No
4
CentOS 7.8
2.17-307
Xeon E5-2650 v4
Yes
No
No
No
5
CentOS 6.7
2.12-1.166
Xeon Gold 6130
Yes
No
No
Khang_N_Intel
Hi Shuo,
I tried your code with the latest version of oneMKL, 2022.1, on Ubuntu 20.04 LTS and didn't see the slowdown that you mentioned.
Can you try the latest version of oneMKL and see if the problem goes away?
Best,
Khang
