Locating Pardiso Example files
S__MPay
As mentioned in MKL Pardiso manual there are example files located in "examples/solverf/source".
But for me I cannot locate those files. I would appreciate if you could tell me why they are missing?
I can only see these files:
djacobi_rci_f_f.htm
ex_nlsqp_bc_f_f.htm
ex_nlsqp_bc_f90_x_f90.htm
ex_nlsqp_f_f.htm
ex_nlsqp_f90_x_f90.htm
sjacobi_rci_f_f.htm
mecej4
On my Windows system, I see that %MKLROOT% terminates with "\mkl", so the directory in question is %MKLROOT\examples\solverf\source". Note that these example files are delivered in zip files in the examples directory, and the zip files need to be unpacked (with directory structure preserved) after installation of Parallel Studio, Composer or MKL distributions.
Alexander_K_Intel2
HI,
I think there is misunderstanding. Example of pardiso functionality places in general MKL directory in folder ${MKL_ROOT}/mkl/examples/solverf/source/. You mentioned examples that are published in manual directory
Alex
Gennady_F_Intel
and for C API -- ${MKL_ROOT}/mkl/examples/solvec/
mecej4
Brian_Murphy
New Contributor II
I have installed visual studio 2019 and intel composer XE 2020.  I cannot find the pardiso examples.  Please help.
I am also finding that a pardiso project of my own that runs well compiled with XE 2013 is failing with XE 2020.  I have no idea why it fails, so I want to see if the example project works.
mecej4
If you open the ...\compiler_and_libraries_2020.0.166\windows\mkl\examples directory, you will see three zip files. You need to unzip these files in order to obtain the individual example source files. After extraction, you will see a subdirectory called ...\solverf\source, within which you will see a number of Pardiso examples. Note that no Visual Studio project files are provided, since these examples all involve very short source files and can be compiled into EXEs using just ifort /Qmkl ... at the command line.
The examples work just fine, and I doubt that building and running them will help much with your Pardiso project problems. You will probably need to provide a bug reproducer for that.
Brian_Murphy
New Contributor II
Thanks, mecej4.  That's where they were.  pardiso_sym_f90.f90 compiled and ran just like it should with XE 2020.
