7303 Discussions
MKL 10.2.4.032 fourier transform functions with LabWindows/CVI 8.1
newbirch
I have problems using MKL with LabWindows/CVI, so I started with a simple program.
Ido fft with the following calls:
length=1000;
ret = DftiCreateDescriptor( &DftiHt, DFTI_DOUBLE, DFTI_REAL, 1, length );
if (!DftiErrorClass (ret, DFTI_NO_ERROR))
MessagePopup( "Error", DftiErrorMessage( ret ));
return;
ret = DftiCommitDescriptor( DftiHt );
if (!DftiErrorClass(ret, DFTI_NO_ERROR)
MessagePopup("Error", DftiErrorMessage( ret ) );
goto FREE_DESCRIPTOR
When the programgets to the commit, I get a general protection error. I have linked mkl_core.lib, mkl_intel_c.lib, mkl_sequential.lib and mkl_solver_sequential.lib. I have included mkl_dfti.h and mkl_types.h. The Compiler is compatible to VisualC/C++; the default calling convention is set to __cdecl.
Have I forgotten something??
mecej4
My suggestion would be to try to run the example directly, using VC. If that works, but using LabWindows causes failure, you would have to seek support from NI. If the VC example also fails, fix the example code and retry.
newbirch
My example works on VC. I've tried it, before asking for help.
But thanks anyway, now I'm looking for help from NI
